Go to Post there should be a continuous cascade of knowledge spilling over to the less experienced team members and and continuous upward flow of members gaining experience. - ebarker [more]
Unread 26-02-2010, 12:12
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
Re: question regarding labview and framework...
I agree with you to an extent. This year's framework is not much different from last year's basic. Here's what is different.
- Each vi is run through a loop AUTOMATICALLY, so no while loops around all of the meaty parts of the code
- Begin == all of anything the robot uses being opened and set into globals (setNumRegestry for this year which replaces annoying global vars)
- Autonomous from last year has been bisected into one of two choices (iterative or Independent)
- Teleop is teleop
- Finish is where everything closes
- everything else is for things like recalibration and what not
Basically, it terminates each program when told without loops, and everything is run from the Main.vi vi. I personally think that this setup made things more specific and complex, while keeping it general enough for anyone to use.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
2010 FRC LabVIEW framework architecture questions Ether NI LabVIEW 8 20-02-2010 21:38
State Machines and Robot Framework aksharma NI LabVIEW 2 15-02-2010 12:33
help with LabVIEW framework Ether NI LabVIEW 10 08-02-2010 21:14
LabVIEW framework realtime architecture Ether NI LabVIEW 2 07-02-2010 12:54
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
