Go to Post You all have ample time to get your sleep in from the final day of nationals to the friday before kickoff. There should be no reason why anyone will need sleep for the next 6 weeks and then some. You all have had enough of sleep or hibernation, now its time to wake up and do some work =). - mtaman02 [more]
  #33   Spotlight this post!
Unread 26-02-2010, 15:35
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: What Are You Doing During Autonomous Period?
Originally Posted by pilum40 View Post
Stupid rookie question....we haven't programmed anything for auto. period. Will that actually cost us? Second dumb question...can we program something for auto. period once we're at the competition?
Our bot is designed to hop the bump, through the tunnel and push ball/play defense. Basically a simple design to run consistently each round without mishaps
Y'all's thoughts?
No need to panic.
The only direct consequence of not having done an autonomous mode is that whatever zone you end up starting in will still have all of the initial balls there at the end of autonomous. This is a significant disadvantage if you're starting in the far zone (relative to your own goals) as that will leave three balls sitting in the near vicinity of one of your opponents goals at the start of teleoperated mode, but it's not likely to be the end of the world. It may make you slightly less desirable at alliance selection time on Saturday if you still don't have one and other teams do, but there are a lot of other variables in that decision.
You can program an autonomous mode on-site at the competition (or now, for that matter, although testing may have to wait a bit). If you need help and ask around at competition, you can almost certainly find a team that will help you.
What are you doing for the flooring? Petey Kit & Additional Hardware 21 06-01-2009 20:01
What are you doing Saturday night? Titan Championship Event 9 09-04-2007 12:58
What are you doing this year? 358_4_Life Rules/Strategy 4 16-01-2007 17:23
What do you do during autonomous mode? Salik Syed Programming 46 21-03-2004 21:05
What are you guys doing so far to practice. fs_2002 Technical Discussion 11 24-10-2002 10:21
