Go to Post They're so cute I could just pinch their little CIM motors!:D :p - Akash Rastogi [more]
Unread 26-02-2010, 12:56
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
0 = 1, but 1 = 1 as well?
so a day before the robot shipped i went to do a final diagnostic on the robot to make sure that everything that was plugged in worked. Our team has 3 solenoids labeled in labview 1, 2, 3 respectively (see picture if needed). I know that 1 = 0 and 2 = 1 etc. however, lately 1 would trigger 1 on the cRio (not 0), and 2 would trigger 2 (not 1). I have neither an idea on what to do, nor an idea of how to fix this.
PS, when debugging, does light on = true or false? I assume that on = true.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 26-02-2010, 14:25
Re: 0 = 1, but 1 = 1 as well?
I don't see the "0" you're talking about.
For that matter, I don't see the "1" or "2" or "3" -- your solenoids are registered with the names "S1" and "S2" and "S3". Can you ask your question with details that match the code you're using? It would also help to see the part of the code that isn't doing what you want it to.
I don't know what debugging light you are talking about either.
Unread 26-02-2010, 15:22
kavisiegel kavisiegel is offline
FRC #0061 (The Shifters)
kavisiegel is an unknown quantity at this point
There shouldn't be a solenoid zero. The solenoid numbers in LabVIEW are directly allocated to the labeled slots in the cRIO Pneumatics Bumper.. which is 1-8.
Most of the time, counting starts at zero, but in this specific case... one is one, and two is two... etc.
Also, yes, true means it's on or open.
www.team61.com
Unread 26-02-2010, 15:55
O.K., 1 = 1 in this case. Thank You
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
Aim Well Alekat General Forum 19 14-02-2006 12:46
Well done 388.... Useless member Regional Competitions 4 10-03-2003 00:00
well lets see... archiver 2001 0 23-06-2002 22:08
So, well, um, what now? Joe Matt General Forum 23 14-06-2002 08:27
