Go to Post This is real. This is hard. This, is FIRST. - sanddrag [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-02-2010, 13:10
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Replacement Kit Parts at Competitions
Has anyone seen a list of replacement parts that FIRST will have available at competitions as yet? Please post a link.
In addition, don't forget to bring unused components from the Kit of Parts that you are not using that other teams might need during each competition. FIRST will only have a limited supply available
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 26-02-2010, 16:21
Hodge1
Smile Re: Replacement Kit Parts at Competitions
Here is the link to the post from FIRST regarding spare parts that will be available in the pit area, along with quantities, for teams that may need them. They usually require you return a defective part when requesting a replacement. As you will see, quantities are limited, so bring Kit parts that you didn't use, as other teams may have a need for them to keep their robots running.
http://www.usfirst.org/uploadedFiles...rts%20List.pdf
Sweat the details
NI Replacement cRIO Kit? R.C. FRC Control System 3 11-05-2009 09:52
Banebot Replacement Parts Ken Loyd General Forum 4 23-02-2007 19:57
Replacement Kit parts rachal Kit & Additional Hardware 4 16-06-2006 21:03
Replacement Parts kaye General Forum 11 21-03-2006 09:34
Replacement Parts archiver 1999 0 23-06-2002 22:01
