Go to Post Trapping JVN (or any other IFI employee) is negative infinity [I]and[/I] a caption contest. Trapping 1114 is a measly 50 points, unless you trap Karthik, which multiplies your entire score by -1. - EricH [more]
  #31   Spotlight this post!
Unread 26-02-2010, 11:12
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: What Are You Doing During Autonomous Period?
Originally Posted by Egg 3141592654 View Post
We deploy, because no amount of pre-charged tank pressure can get that kicker going in enough time to do much
What do you mean about "No amount of Pre-Charged Tank Pressure"?
I'm not trying to challenge your post or anything, but you can completely charge your pneumatic system before you walk on the field. That's what we're going to do and I know quite a few teams do this as well.
-Dustin Benedict
  #32   Spotlight this post!
Unread 26-02-2010, 12:51
drtysteve384 drtysteve384 is offline
AKA: Christian
FRC #0384 (Sparky 384)
drtysteve384 is on a distinguished road
We were going to locate the ball with our camera and then use our kicker to kick it in to the goal... but only if we were in the scoring zone...if not i think we would just kick them across the field...
  #33   Spotlight this post!
Unread 26-02-2010, 14:54
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Stupid rookie question....we haven't programmed anything for auto. period. Will that actually cost us? Second dumb question...can we program something for auto. period once we're at the competition?
Our bot is designed to hop the bump, through the tunnel and push ball/play defense. Basically a simple design to run consistently each round without mishaps
Y'all's thoughts?
  #34   Spotlight this post!
Unread 26-02-2010, 15:35
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Y'all's thoughts?
No need to panic.
The only direct consequence of not having done an autonomous mode is that whatever zone you end up starting in will still have all of the initial balls there at the end of autonomous. This is a significant disadvantage if you're starting in the far zone (relative to your own goals) as that will leave three balls sitting in the near vicinity of one of your opponents goals at the start of teleoperated mode, but it's not likely to be the end of the world. It may make you slightly less desirable at alliance selection time on Saturday if you still don't have one and other teams do, but there are a lot of other variables in that decision.
You can program an autonomous mode on-site at the competition (or now, for that matter, although testing may have to wait a bit). If you need help and ask around at competition, you can almost certainly find a team that will help you.
  #35   Spotlight this post!
GaryVoshol's Avatar
Cogito ergo arbitro
Maybe a little. Work with your alliance partners. Ask them where they want you to set up so you are out of their way.
Absolutely. Get some help on Thursday. There are plenty of good teams on the regional list. The best ones will be able to teach you how to program something for auton, not just do it for you.
(since 2004)
  #36   Spotlight this post!
Unread 26-02-2010, 15:37
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
can your camera find the ball now? I would be interested in the code, as we are having some trouble locating the ball
Watchdog.Kill();
  #37   Spotlight this post!
Unread 26-02-2010, 17:49
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Originally Posted by Chris is me View Post
You shouldn't need to track the ball. It starts exactly where you put it every match.
You are also allowed to precharge your pneumatics, so you shouldn't need to use auto mode to do that.
What my team WAS going to do in auto was to have several modes with an adjustable 0-15 series of switches for delay. Then we got the kicker working an hour before we had to crate, and we still lack a posession mechanism. So... probably just 3 autos, "kick em forward".
Rule please?
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
  #38   Spotlight this post!
Unread 26-02-2010, 17:59
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Originally Posted by GGCO View Post
Rule please?
<G09> BALL Starting Positions – Prior to the MATCH, each ALLIANCE is provided with six BALLS to be placed on the FIELD.
Lots of people have been confused on this one. It says the ALLIANCE places the balls
<R75> *snip*The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the FIELD. Off-board compressors must be controlled and powered by the ROBOT.
Basically, you can use another compressor as long as it is powered and controlled by the robot while off the field
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #39   Spotlight this post!
Unread 27-02-2010, 08:41
Big Kid's Avatar
Big Kid Big Kid is offline
The Coach
AKA: Nick Acosta
FRC #0816 (WesTech Anomaly)
Big Kid is a jewel in the roughBig Kid is a jewel in the roughBig Kid is a jewel in the rough
Send a message via AIM to Big Kid
Originally Posted by thefro526 View Post
Crying - Because we don't have an autonomous mode.
Or
Yelling - Because our programmer didn't make an autonomous mode.
It's 50/50 either way.
Or he going to be proud because I have an untested autonomous mode that should work in two out of three positions
Team 816
Student (2007-2011)
Mentor/Drive Coach (2013-)
Team 2495
Mentor (2016-)
Graduate Mech. Engineer at Lehigh University
  #40   Spotlight this post!
Unread 27-02-2010, 13:54
Chris is me's Avatar
AKA: Pinecone
It was also my understanding that there is no rule requiring your pneumatic system to begin a match at 0 PSI, even if you have an onboard compressor... I'll find the rule in a minute.
  #41   Spotlight this post!
Unread 27-02-2010, 23:42
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
<R01-B> allows for 120 PSI stored at the start of the match in up to 4 Clippard tanks.
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R40> for specifications and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
Emphasis mine
  #42   Spotlight this post!
Unread 28-02-2010, 13:04
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
What i mean is that our kicker is a long range kicker, and takes FOREVER to set up (Piston is too small), but once it is set, it takes a few seconds to reset after that.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
  #43   Spotlight this post!
Unread 28-02-2010, 13:50
pschre's Avatar
pschre pschre is offline
Teacher Coach
AKA: James Schreiner
FRC #0806 (Brooklyn Blacksmiths)
pschre will become famous soon enoughpschre will become famous soon enough
Send a message via AIM to pschre
If all goes well (chiefly our programmer figuring out how to get what he wants out of the encoders - and if not I guess he'll dead reckon using time) we should have about 16 different autonomous options, selectable with a rotating potentiometer dial (a clicking one would have been nice, but pre-match we'll just have to tether the Classmate to the robot and make sure we stop the dial at the appropriate number). Options such as: get out of our partners' way in the first 5 seconds, wait the next 5 seconds, and flick the ball over the hump/into the goal in the last 5 seconds, and various combinations thereof.
"In this life we cannot do great things. We can only do small things with great love." -- Mother Teresa
"You give yourself to us, O Lord, then selfless let us be, to serve each other in Your name, in truth and charity." -- Robert E. Kreutz, You Satisfy the Hungry Heart
"You have the right to work, but for the work's sake only. You have no rights to the fruits of work. Desire for the fruits of work must never be your motive in working. Never give way to laziness, either...Work done with anxiety about results is far inferior to work done without such anxiety, in the calm of self-surrender...They who work selfishly for results are miserable." -- from the Bhagavad Gita, quoted in Educating Esmé
  #44   Spotlight this post!
Unread 01-03-2010, 21:42
jblay's Avatar
jblay jblay is online now
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Hope that it doesn't mysteriously stop working in the eliminations and that it doesn't stop us from moving at all.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #45   Spotlight this post!
Unread 01-03-2010, 22:01
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by pschre View Post
...our programmer figuring out how to get what he wants out of the encoders - and if not I guess he'll dead reckon using time...
If he wants help with the encoders, tell him to ask. There are many people here who would gladly help him.
As for that potentiometer thing, you can have dashboard indicators on your Classmate during Disabled, and see it there.
Kettering Motorsports
What are you doing for the flooring? Petey Kit & Additional Hardware 21 06-01-2009 20:01
What are you doing Saturday night? Titan Championship Event 9 09-04-2007 12:58
What are you doing this year? 358_4_Life Rules/Strategy 4 16-01-2007 17:23
What do you do during autonomous mode? Salik Syed Programming 46 21-03-2004 21:05
What are you guys doing so far to practice. fs_2002 Technical Discussion 11 24-10-2002 10:21
