Go to Post Hmmm, the Michelangelo method of robot building. Just cut away anything that doesn't look like a robot. - GaryVoshol [more]
Unread 20-02-2010, 22:45
Alexandstein Alexandstein is offline
FRC #2192 (YAK Attack)
Alexandstein is an unknown quantity at this point
Negatives not working.
In our robot code, we are attempting to program a motor to go forward for .5 seconds, and then go backwards for another .5 seconds at the press of a button, but for some reason, negative numbers are not working. The motor goes forward for .5 seconds, and goes forward again instead of backwards.
For the motor speed we have -0.5 entered in.
We tried controlling the motor to go backwards and forward using the throttle axis on the joystick it worked fine.
Thanks for any help!
Unread 21-02-2010, 08:16
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
Re: Negatives not working.
can you post your code?
Unread 21-02-2010, 09:51
-0.5 is usually forwards. That's what your throttle sends.
It's probably the positive speed value that's causing you trouble.
Unread 21-02-2010, 12:49
What can I do to fix that?
We just tried having one value 0.5 and another value of 0.5 connected to a negate function, then connected to the motor speed control. Again, no luck.
Thanks for all help you can give.
Unread 26-02-2010, 11:23
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
one of your motors could be wired backwards, in this case, just go to Begin and click true for isInverted(), of course, that is if this motor is an issue for all your states.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 26-02-2010, 23:50
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
A negate function?
Try just wiring a constant -0.5 to the motor, it worked fine for us.
EDIT: eh, reading your first post again, it looks like that's the first thing you tried
Jaguars not working mama_tree Electrical 8 01-02-2010 07:54
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Gyro not working 1594code Programming 2 12-02-2008 18:16
Negatives in Binary Michael Hill Math and Science 12 10-02-2007 21:28
