#31
Re: What Are You Doing During Autonomous Period?
I'm not trying to challenge your post or anything, but you can completely charge your pneumatic system before you walk on the field. That's what we're going to do and I know quite a few teams do this as well. |
#32
We were going to locate the ball with our camera and then use our kicker to kick it in to the goal... but only if we were in the scoring zone...if not i think we would just kick them across the field...
#33
Stupid rookie question....we haven't programmed anything for auto. period. Will that actually cost us? Second dumb question...can we program something for auto. period once we're at the competition?
Our bot is designed to hop the bump, through the tunnel and push ball/play defense. Basically a simple design to run consistently each round without mishaps Y'all's thoughts? ![]() |
#34
The only direct consequence of not having done an autonomous mode is that whatever zone you end up starting in will still have all of the initial balls there at the end of autonomous. This is a significant disadvantage if you're starting in the far zone (relative to your own goals) as that will leave three balls sitting in the near vicinity of one of your opponents goals at the start of teleoperated mode, but it's not likely to be the end of the world. It may make you slightly less desirable at alliance selection time on Saturday if you still don't have one and other teams do, but there are a lot of other variables in that decision. You can program an autonomous mode on-site at the competition (or now, for that matter, although testing may have to wait a bit). If you need help and ask around at competition, you can almost certainly find a team that will help you. |
#35
can your camera find the ball now? I would be interested in the code, as we are having some trouble locating the ball
#37
<G09> BALL Starting Positions Prior to the MATCH, each ALLIANCE is provided with six BALLS to be placed on the FIELD.
Lots of people have been confused on this one. It says the ALLIANCE places the balls <R75> *snip*The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the FIELD. Off-board compressors must be controlled and powered by the ROBOT. Basically, you can use another compressor as long as it is powered and controlled by the robot while off the field |
#39
Or he going to be proud because I have an untested autonomous mode that should work in two out of three positions
#40
If all goes well (chiefly our programmer figuring out how to get what he wants out of the encoders - and if not I guess he'll dead reckon using time) we should have about 16 different autonomous options, selectable with a rotating potentiometer dial (a clicking one would have been nice, but pre-match we'll just have to tether the Classmate to the robot and make sure we stop the dial at the appropriate number). Options such as: get out of our partners' way in the first 5 seconds, wait the next 5 seconds, and flick the ball over the hump/into the goal in the last 5 seconds, and various combinations thereof.
#44
Hope that it doesn't mysteriously stop working in the eliminations and that it doesn't stop us from moving at all.
#45
As for that potentiometer thing, you can have dashboard indicators on your Classmate during Disabled, and see it there. |
| What are you doing for the flooring? | Petey | Kit & Additional Hardware | 21 | 06-01-2009 20:01 |
| What are you doing Saturday night? | Titan | Championship Event | 9 | 09-04-2007 12:58 |
| What are you doing this year? | 358_4_Life | Rules/Strategy | 4 | 16-01-2007 17:23 |
| What do you do during autonomous mode? | Salik Syed | Programming | 46 | 21-03-2004 21:05 |
| What are you guys doing so far to practice. | fs_2002 | Technical Discussion | 11 | 24-10-2002 10:21 |
