Go to Post it is actually more important to understand and be able to clearly state the question than it is to know the answers. - GeeTwo [more]
  #31   Spotlight this post!
Old 26-02-2010, 14:31
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Re: Mysterious Screw
1625 has used leadscrews very successfully in the past. In 2006 it was used to actuate the hood on our turreted shooter and in 2008 it was used to bring our shooter from pick-up to shooting position.
  #32   Spotlight this post!
Old 27-02-2010, 01:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Large versions of this little screw are used to adjust position on satellite dishes all over the world. I work with one dish that has a lead screw for elevation and it is connected to a 3/4 HP motor with an electric brake. The screw is about 4' long and at least 2" in diameter. Another dish that is much larger has two, one for azimuth and one for elevation. Both can be operated by a hand crank or electric drill attachment. The dish is 6 meters in diameter.
The dishes I worked on way back when used gear drive...10 meters with a pretty heavy equipment room attached to the az drive....
If you ever get the chance to peer into the workings of a 1957-59 Ford Retractable car, you can see several lead screws. An engineering marvel.
  #33   Spotlight this post!
Old 27-02-2010, 03:52
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
6 motors too
2017 Season; Game Announcer at
SBPLI Long Island Regional
  #34   Spotlight this post!
Old 27-02-2010, 14:01
Jim,
Our old 10 meter C band dish had manual adjustments for azimuth but luckily was a polar mount. As I remember, the lead screw transmission had another right angle gear reduction box on it. It moved exceedingly slow. We only had to aim once when the main PBS satellite reached end of life and we had to reposition.
  #35   Spotlight this post!
Old 27-02-2010, 15:07
MrForbes's Avatar
AKA: Jim
I guess that X band stuff was more finicky about where you point the antenna...or it was just that some of the birds were about out of gas and moved around a lot..but our tracking systems ran full time
  #36   Spotlight this post!
Old 27-02-2010, 16:08
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by Taylor View Post
From what I hear, on team 829 the Head Time-Waster becomes the Lead Button-Maker.
Because after a day of cutting out circles with scissors your hands are so cramped up you cant operate the lead screw anymore.
Mysterious noise keeps couple awake in their home - no source found! Elgin Clock Chit-Chat 12 25-07-2008 08:58
pic: Screw 1 Robo_Coyote Extra Discussion 3 03-02-2007 02:14
Compressor screw attachments? blue_crew Pneumatics 2 11-02-2006 16:46
Archimedes Screw Greg Perkins General Forum 10 19-01-2005 11:19
Terminal Screw Strips? Jay05 Electrical 2 09-03-2003 21:48
