Go to Post Let's see. There's the Dean of Students, the Dean of Admissions, The Dean of Engineering, and the Dean of Kamen? Sometimes known as the Denim Dean. - Bill_B [more]
Unread 27-02-2010, 12:55
NinjaWithBurnin NinjaWithBurnin is offline
Professional FBI-C
AKA: The Ender
FRC #1749 (Renesiance)
Rookie Year: 2015
NinjaWithBurnin is an unknown quantity at this point
Rotation sensors
Hey
Does anyone know how to get rotation sensors to work in LabView?
we are trying to get the to work for autonomous mode
So foar I have found that they are under encoders in Labview, but still do not know how to get them to work
Thanks everyone
Registered Assassin & Bodyguard
Unread 27-02-2010, 13:03
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Rotation sensors
Which rotation sensors are you using? I've been looking for a good set for a long time!
Jacob
Unread 27-02-2010, 13:09
Professional FBI-C
AKA: The Ender
Rookie Year: 2015
Just the ones that came with the KOP
most likely the ones off andy mark
Unread 27-02-2010, 13:18
It's a bit complex, but LabVIEW has an example (Encoder Example) that spells out all that you need to setup. It assumes a digital quad encoder, so a different type, such as a single or an analog one that came in the KOP with the magnets, would be handled differently.
From the Getting Started window select "More..." at the bottom right under Examples.
Then select "Encoder Example"
Open up the Block diagram and you can copy/paste the code over to your project.
It breaks down like this:
Begin.vi
  • DIO Opens for two channels (assuming a quad encoder like the KOP US Digital ones)
  • Convert to Digital Source
  • Encoder Open
  • Encoder Config Timer
  • Encoder Start
  • Encoder Refnum
Autonomous Independent.vi
  • Encoder refnum
  • Encoder Get
Finish.vi
  • Close encoder
Checkout http://www.usdigital.com/first for the encoder assembly guide.
Unread 27-02-2010, 14:20
AKA: Jacob Komar
Ah, the wheel encoders. I thought you had meant just a simple rotation sensor.
Jacob
Unread 27-02-2010, 16:26
Professional FBI-C
AKA: The Ender
Rookie Year: 2015
Thank you, I figured out how to start them
can you post some diagrams of how I could use the encoders control the motors in the autonomous mode?
Thanks
Rotation Sensors brennerator Electrical 6 09-02-2007 09:18
Rotation Systems Goaliexam Technical Discussion 9 06-06-2006 17:56
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Yellow Rotation Sensors ? de_ Electrical 6 26-04-2005 15:40
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
