Go to Post ...several people have told my that my brain has been oxygen-starved since at least 1975. - dlavery [more]
Unread 22-02-2010, 17:39
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Is there an easy way to download all the source code for WPILib C++ v4.3 at once?
Our robot design makes it difficult to install wheel encoders this year, so we decided to use the accelerometer to do the job of encoders telling us how far the robot has travelled. It will be used during autonomous mode to run a programmed path (e.g. go forward 10 ft). We will reset the accumulator before each segment run. Each segment run is a straight line on level ground. Therefore, I think we may be able to pull this off with the accelerometer.
Unread 27-02-2010, 17:22
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
We found two years ago that the accelerometer is not accurate enough for navigation. It is designed to detect bumps to deploy air bags and is not very accurate at all.
Unread 27-02-2010, 17:25
mikets's Avatar
Software Engineer
Thanks for the info. But this is too late now. This would be our learning experience of using the accelerometer. We will try to make the best use of it.
WPILib source code now posted BradAMiller C/C++ 5 21-02-2010 23:21
For all the Billfred fans out there ROBOmasta Chit-Chat 5 16-02-2009 11:58
Source code for the Easy C Pro library functions? bobpskier Programming 3 05-02-2007 21:39
For all the P-Ballers out there Andrew Y. Chit-Chat 13 23-11-2005 22:42
Happy Eid for all the Muslims out there!! Matt Attallah Chit-Chat 4 13-11-2004 16:47
