Go to Post Its easier to solve a problem when you have a positive attitude about it. - Arefin Bari [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-02-2010, 21:01
Re: Spectra Cable Source
Originally Posted by Tom Line View Post
Usually in the neighborhood of 500-600 lbs (tensile). Be aware that a knot will drop the strength by as much as 50%, and that you should use a thimble to prevent it from kinking and chafing unless you're going around a solid shaft. Spectra is notorious for chafing (even though it is more chafe resistant that other aramids).
Are there any better/stronger crimps than those available through SmallParts and the ones that come with the cable?
Source for DC37 Extension Cable MikeDubreuil FRC Control System 3 12-01-2009 22:50
Spectra Cable computerboi1503 Technical Discussion 7 09-02-2008 00:35
Y-Cable CaptainPlaid Technical Discussion 0 13-02-2002 12:55
CABLE BOOTY BURGLAR OCCRA 2 30-09-2001 13:10
Cable Modems Carolyn Duncan Chit-Chat 14 06-08-2001 11:00
