Go to Post It's not easy dealing with the reality that others aren't as passionate as we are and that the process may be slower than we want it to be - but it gives me plenty of time to think and prepare. - JaneYoung [more]
Unread 26-02-2010, 19:15
lollypop2020 lollypop2020 is offline
FRC #2733 (Pigmice)
lollypop2020 is an unknown quantity at this point
Is Alliance/Position automatically set by the FMS?
Last year, I believe it was, but I am slightly concerned because you can set your own alliance and position on your DS. It's fine either way, I just need to know which it is.
Thanks!
Unread 26-02-2010, 19:24
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Is Alliance/Position automatically set by the FMS?
The alliance and position will be set by FMS. Alliance is obvious, but position is the position of the controls, not the robot.
Kettering Motorsports
Unread 26-02-2010, 23:39
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Do you know that for sure? Without FMS, the drop down box on the classmate does get passed to the robot, is it different when the FMS is running things?
Unread 27-02-2010, 04:56
When attached to the FMS, the drop down box is hidden and the values from the FMS are used instead.
Greg McKaskle
Unread 27-02-2010, 21:41
FRC #2733 (Pigmice)
Aha! That's very helpful. So for our robot's actual starting position on the field, I know we can use a toggle switch on our robot, but would it work to have a toggle switch on the driver's station(likely joystick buttons)? We would need it to update before autonomous and I'm not sure if the robot can read values from the joysticks before teleop.
Unread 27-02-2010, 21:43
The robot can read from the joystick buttons and DS I/O every time except autonomous enabled.
Unread 27-02-2010, 21:45
ATannahill ATannahill is offline
AKA: Alex Tannahill
If it goes like last year (I think it will) the robot will be able to read values before autonomous while disabled.
- Arizona North
Unread 27-02-2010, 22:44
We've been told that it won't go exactly like last year. The difference is that during autonomous enabled the joystick values will not be forced to "neutral". The robot will see them locked in the state they were in immediately before autonomous enabled began. This simplifies things greatly if you want to use a Driver Station control for selecting automode subprograms.
[FTC]: FMS Dropping only the joystick possibly? ttldomination FIRST Tech Challenge 8 24-02-2009 18:13
Set Alliance Color whitetiger0990 FRC Control System 4 31-01-2009 16:58
Moving the robot automatically to follow camera tracking potnisanish Programming 3 29-01-2009 21:01
[FTC]: Field Timer (similer but not the FMS) team2845 FIRST Tech Challenge 0 19-12-2008 17:52
Best Alliance in the Alliance Era of FIRST Corey Balint General Forum 28 05-09-2006 20:14
