Go to Post Be yourself and do what you love. - Greg Marra [more]
Unread 27-02-2010, 23:46
CrashOverride's Avatar
CrashOverride CrashOverride is offline
FRC #1831
CrashOverride is an unknown quantity at this point
Quadrature Encoder Wiring to Digital Sidecar
I need help understanding the correct wiring scheme for the quadrature encoder from usdigital.
There are 4 leads:
1. +5
2. channel A
3. Gnd.
4. channel B
I have tried connecting +5 and ground to the spare +5 and ground connectors next to the digital inputs on the digital sidecar and each of the channels to the signal pin on a individual digital in port on the sidecar. I have tried connecting the ground pins on digital in ports to a common ground and leaving the ground on the digital in ports unconnected.
The results are fairly consistent: things will work for a few seconds then everything connected to the sidecar stops, the victors and jaguars LED starts to blink like the would if there was no PWM cable connected.
I haven't been able to find any documentation either on the FIRST site or on the usdigital site that specifically covers how to connect this encoder.
Ignorance is definitely not bliss today!
Any help would be greatly appreciated.
Unread 27-02-2010, 23:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Quadrature Encoder Wiring to Digital Sidecar
For easier troubleshooting of your problem, please stick to one thread. This will help others see what has already been tried/recommended.
Quadrature Encoder Wiring to Digital Sidecar CrashOverride Electrical 7 23-06-2010 15:32
Wiring Digital Sidecar rsegrest Electrical 7 25-01-2010 11:25
Problem with quadrature encoder Steve Compton Programming 13 14-03-2009 11:16
Help Programming a Quadrature Encoder programmr Programming 17 20-06-2008 10:40
Quadrature shaft encoder source billbo911 Kit & Additional Hardware 7 06-01-2008 19:52
