Go to Post Good thing you skipped this year. You don't need exhaustion to sleep through Recycle Rush. - Gregor [more]
Unread 28-02-2010, 16:04
C3PO C3PO is offline
C3PO has a spectacular aura aboutC3PO has a spectacular aura about
controling more than one air cylinder with a single valve
Is it legal to use two air cylinders controled by one Festo valve? In other words, we would "T" the air line after ONE Festo valve to energize and then retract TWO air cylinders. Any help would be greatly appreciated.
Sincerely,
C3PO
Unread 28-02-2010, 16:08
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: controling more than one air cylinder with a single valve
Absolutely. Done it many times.
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Absolutely legal. This works well if they're smaller cylinders. If they are large, you may encounter flow issues - i.e. your pistons will move slowly.
We use this sytem to shift our trannies simultaneously.
Unread 28-02-2010, 16:18
Thank you very much. You guys, ALL of you out there, are absolutely GREAT!!
C3PO
More than one team?? Phoenix Spud CD Forum Support 2 16-06-2009 12:19
More than one regional? keehun General Forum 8 02-05-2009 22:26
More than One Regional? smurfgirl Regional Competitions 35 26-03-2008 14:21
More than two air tanks? Mercutio Pneumatics 6 10-02-2004 16:07
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
