Go to Post When your team becomes ubiquitous with the phrase "Always a bridesmaid, never the bride" - Peyton Yeung [more]
Unread 20-02-2010, 14:11
HAL3019's Avatar
HAL3019 HAL3019 is offline
AKA: Mike LiBretto
FTC #3019 (HAL)
HAL3019 is an unknown quantity at this point
Send a message via AIM to HAL3019
[FTC]: Use of Non-Slip Pad?
We are encountering some comprehension problems when we go to use the non-slip pad. How would one go about mounting it to a Tetrix building element?
Thanks in advance,
Team HAL
Unread 20-02-2010, 17:12
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: [FTC]: Use of Non-Slip Pad?
zip ties, bolts, metal cable,or rope.
you can zip tie/bolt through the holes in the grip cloth
I hope this helps.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 21-02-2010, 16:56
HAL3019's Avatar
AKA: Mike LiBretto
FTC #3019 (HAL)
Thanks, and are there rules regarding SCREWING a lego tire into a 3in wheel so that it wont walk off when the wheels are spun.
Unread 21-02-2010, 16:58
AKA: Steven Harris
nope. not that i know of. but check the rule book.
Unread 28-02-2010, 20:09
FLHSFTC FLHSFTC is offline
FLHSFTC is an unknown quantity at this point
I actually utilized some ropes that we were allowed to use. Not the huge ones but the size of a thread or like yarn. I had used my sowing skills and eventually sowed the non slip pad together or for any other purposes. Zip ties, I believe fishing wire is allowed, and many more, you should look at the manual, they helped me a lot since they gave me an idea on what we should use and not to. Good luck!
Unread 11-11-2010, 18:14
bstrong1218's Avatar
bstrong1218 bstrong1218 is offline
Brandon
AKA: Brandon
FRC #3344 (Robocopz)
bstrong1218 is an unknown quantity at this point
Any idea what counts as "non-slip pad" This year's rules specify some examples which are a shelf liner, but our team used the type of non-slip pad sold to set on a car dash (for cell phones, wallets, etc.). We were cautioned against it although the judge didn't seem quite sure.
Unread 11-11-2010, 21:39
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
We are currently working on developing and implementing our first conveyor belt system and while trying to figure out how to properly tension and join the ends of the belt, non-slip pad, we found that the best way is to take two flat bars and sandwich then overlap the two ends between them, then screw the flat bars together as tight as possible. The belt will deform before it comes apart.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
help on the non-slip program wildcats Electrical 2 13-01-2009 23:59
[FTC]: Use of VEX in Tetrix ttldomination FIRST Tech Challenge 7 11-01-2009 17:42
[FTC]: Non-technical topics during interview ManicMechanic FIRST Tech Challenge 0 28-12-2007 00:53
Use of non-autodesk software? Eric Reed 3D Animation and Competition 19 04-11-2004 20:20
Is the use of slip rings legal? dradius Technical Discussion 9 26-01-2004 19:26
