Go to Post Cant get hair and nails done and still run a robot. - wendymom [more]
Unread 28-02-2010, 20:15
FLHSFTC FLHSFTC is offline
FLHSFTC is an unknown quantity at this point
Re: [FTC]: 4 Stage Gear Train HELP!
1: 36 is actually too much, you don`t even need that much. 1: is pretty efficient because it can pretty much shoot over 5-6 feet, but less then 10 feet. I believe that if you should over that much, it would be considered a penalty. If you try to make the robot go for 1:9 ration on a shooter with only running 1 motor, it would not go as far as having two motors having the ration of 1:9. overall 1;36 is too much power 1:9 is just right.
Unread 06-03-2010, 10:49
HAL3019's Avatar
HAL3019 HAL3019 is offline
AKA: Mike LiBretto
FTC #3019 (HAL)
HAL3019 is an unknown quantity at this point
Send a message via AIM to HAL3019
The way in which we are launching the balls calls for it, because we are trying to accelerate the ball using 2/3 of a wheel's rotation. Yeah... I know its a bit much, but we got it working around a week ago, we had to re-arrange the order of the gears in the train, plus we are working at maybe 50% power... so it should be 1:18 (we tried it, and it didn't have enough "weight" on the ball). Thank you all for your replies.
HAL
FP Gearbox: Last stage gear? Manoel Motors 5 04-02-2009 16:12
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: [FTC]: HELP! Multiple fields set up!!! galewind FIRST Tech Challenge 10 16-12-2007 09:53
2 Gear Drive Train AT man General Forum 31 12-02-2003 19:05
