Go to Post MAVERICKS, do ride horses...all while building robots. They also build horses. - Corey Balint [more]
Unread 14-11-2001, 00:23
gail gail is offline
#0469 (Las Guerrillas)
gail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to all
fasteners
Is it legal to fasten wire and pneumatic tubing with plastic spiral wire wrap?
May cotterless hitch pins be used as a fastener?
Unread 14-11-2001, 06:32
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Yes you may use plastic spiral wrap for wires & tubing -- Counts as a fastner as far as I can tell.
Yes you may use X as a fastener, provided it meets the definition we have set for fastners. In this case X is a cotterless hinge pin. You may have others.
Joe
Q&A166: Bolts are fasteners. Period archiver 2001 0 24-06-2002 00:25
threaded rod fasteners... archiver 2001 1 24-06-2002 00:08
Are Shaft Collars fasteners? archiver 2000 1 23-06-2002 23:10
Interested in Extrusions and Fasteners? Andy Baker Technical Discussion 16 11-01-2002 19:01
Are Grommets considered fasteners? kmcclary Off-Season Events 1 04-11-2001 17:26
