Re: Quadrature Encoder Wiring to Digital Sidecar
Thanks for the help guys!
The problem turned out to be the digital sidecar. This didn't occur to me because without the encoder the victors, jaguars and spikes worked fine. I assumed that we had not wired the encoder correctly. The battery LED was not lit even though all power sources were correctly wired. We replaced the sidecar with one that had all three LED lit and everything worked perfectly as built. |
| Wiring Digital Sidecar | rsegrest | Electrical | 7 | 25-01-2010 11:25 |
| Problem with quadrature encoder | Steve Compton | Programming | 13 | 14-03-2009 11:16 |
| Help Programming a Quadrature Encoder | programmr | Programming | 17 | 20-06-2008 10:40 |
| Quadrature shaft encoder source | billbo911 | Kit & Additional Hardware | 7 | 06-01-2008 19:52 |
| Turning a gear-tooth sensor into a quadrature output encoder | Jared Russell | Programming | 4 | 18-01-2006 22:19 |
