Go to Post However I do wish to reassure people that the judges did not just fall off the back of a turnip truck... - dtengineering [more]
Unread 01-03-2010, 16:25
gokul gokul is offline
FRC #0571
gokul is an unknown quantity at this point
Can we detect if PSoC is connected or not ?
Hi All,
Is there a way to detect (from within Windriver C/C++) if the PSoC is connected to the Driver Station or not ?
I would like the code to do some functions in the standard mode if there is no PSoC attached. If it is attached then the code will do additional enhanced functions using the enhanced class.
Any ideas?
Thanks
Gopal
Unread 01-03-2010, 16:49
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Can we detect if PSoC is connected or not ?
You could jump an input to power and detect if the input is high
I also heard that if you call GetConfiguration (or something like that) and it returns kUnknown then the PSoC is most likely not connected (unless you set that in the ds configuration)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 02-03-2010, 00:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I know that in labview, if the board is not connected and you have error reporting turned on the first message you get on your user diagnostics screen is one reporting that there is an error or the board is not plugged in.
Since I believe that information is getting packaged up and sent from the robot, I'd wager you can unpackage it on the robot to check it against a string etc.
This is all in labview, however, and I'm not sure what language you're using. I haven't dug deeply into the pre-packaged error information, though I know you can see it in one of the clusters when running the code from your developement computer as well.
Unread 02-03-2010, 01:37
Since that message (and the one about the IP address) shows up even if the cRIO isn't turned on, I'm pretty sure it isn't coming from the robot.
Unread 03-03-2010, 11:22
FRC #0571
That sounds good, and I will check on the GetConfig also - Thanks
Gopal
Unread 03-03-2010, 11:24
FRC #0571
My first line says Windriver C/C++ so it is not Labview.
The error message is local to the driver station laptop - it is not coming from the robot (as Alan also points out).
Thanks
Another pneumatics question DPPT1717 Pneumatics 8 11-01-2007 23:38
Another CIM Question Carlo Motors 4 14-02-2005 22:02
Ok another question Rhs953 Motors 2 30-01-2004 23:05
Another Question. Jacob Morgan Electrical 6 05-01-2004 18:32
Another rules question archiver 2001 1 24-06-2002 00:01
