Go to Post Am I just a freak? - Josh Hambright [more]
Unread 02-03-2010, 01:01
Chris is me's Avatar
AKA: Pinecone
Re: Extending before finale?
Why would any rules prohibit actuation of anything within the FRAME PERIMETER? I don't see how this could possibly ever be illegal. I guess Q&A it, but this seems really open and shut...
Unread 02-03-2010, 01:21
They prohibit active mechanisms controlling the balls above the bumper zone, don't they?
Unread 02-03-2010, 19:21
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
so long as you stay within the normal teleop frame and do not use any moving parts above the bumperzone to interact with the ball, it's fine
Unread 02-03-2010, 19:38
FIRSTgirl675's Avatar
FIRSTgirl675 FIRSTgirl675 is offline
AKA: Stephanie
FRC #0675 (Tech High Robotics)
FIRSTgirl675 will become famous soon enoughFIRSTgirl675 will become famous soon enough
I would also have to say to send this one to the Q & A.
From what I understand of the rules (and from what others have stated to me) your robot has to stay in the configuration it is in at the beginning of the match until the finale unless you are in contact with your alliances tower. At that point you can go outside of the normal configuration and can set up your finale piece before the finale, but as I stated I would send this one to Q & A.
Unread 02-03-2010, 19:57
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
This actually got me thinking. Since you are allowed to exit the frame perimeter for 2 seconds, could you start hanging at 22 seconds?
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 02-03-2010, 20:03
Vikesrock's Avatar
Happy Birthday! Vikesrock Vikesrock is offline
Team 2175 Founder
AKA: Kevin O'Connor
The 2 second exemption allowed by <G30-A> only applies to mechanisms below the bumpers and must be for the purpose of interacting with the ball.
You can hang whenever you want if you touch the tower the whole time you do so, or stay inside your FRAME PERIMETER while doing so.
Unread 02-03-2010, 20:14
GaryVoshol's Avatar
Cogito ergo arbitro
It's already been asked, and the GDC is OK with it: http://forums.usfirst.org/showthread.php?t=14096
There is no rule that would prohibit parts of the ROBOT from expanding/contracting within the limits of the NORMAL CONFIGURATION and the vertical projection of the FRAME PERIMETER.
(since 2004)
Unread 03-03-2010, 00:26
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
I think I found an answer to my second question while browsing a different section of the Q&A:
http://forums.usfirst.org/showthread.php?t=13730
As defined in Section 6.2.4 of The Manual, the TOWER includes the base and the pipe superstructure. The PLATFORM and the TUNNEL are features of the base, and are therefore part of the TOWER. The carpet under the TOWER is not considered part of the TOWER.
So, because the PLATFORM and TUNNEL are a part of the base, and the base is a part of the TOWER, touching the PLATFORM or TUNNEL means you are touching the TOWER which means you are then able extend to FINALE CONFIGURATION before the FINALE starts. Right? >_>
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 03-03-2010, 00:47
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Haha main you got me confuzed
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
Unread 03-03-2010, 08:27
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
That is my interpretation as well, but you might want to ask the head referee at the drivers meeting on Thursday morning, just to make sure.
___________________
- Tennyson, Ulysses
Unread 03-03-2010, 16:18
Bob Steele's Avatar
AKA: Bob Steele
Let me ask this another way...
Why would they have the rule if the base of the tower was NOT part of the tower.
How could you touch anything inside it ?? You are not allowed to come out of your frame perimeter extended vertically... the only thing you will be able to touch the tower with is your bumpers.... so ergo... touching the tower means your bumpers are touching the base of the tower...
So prior to the 20 second finale... your bumpers better be nestled up against the tower base somehow...
if you want to extend outside your frame perimeter...
Anything that happens within the frame perimeter is ok unless you are trying to control a ball above the bumpers...
I cannot see how this could possibly be interpreted any other way...
I may be wrong...
I have been wrong before...
There was that time last year when I thought I had made a mistake...
but I hadn't...
see you on the field
Extending IR board connector wires 7-11number1 Electrical 8 14-01-2008 21:49
Extending objects Booger Inventor 10 14-07-2006 13:04
height violation while extending gondorf Rules/Strategy 13 20-01-2006 08:33
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
pic: Vex before extending Not2B Extra Discussion 5 17-04-2005 22:01
