Go to Post OMG, yet another blatant attempt by FIRST at being open and transparent! What is this place coming to?? :p - DonRotolo [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 15-02-2010, 20:19
PICgnosis's Avatar
PICgnosis PICgnosis is offline
AKA: Karen Suhm
FRC #0842 (Falcon Robotics)
PICgnosis is on a distinguished road
Re: Wiimote Digital Scouting System
Originally Posted by Core2idiot View Post
Okay, I have been playing with the 2010 Wiimote scouting program. first of all I have problems installing the driver for the wiimote on windows 7 on a Macbook (Late 2009) (I am using built in BT) It says that the device cannot start (but that doesn't always happen) When I do manage to get the driver to install I can't figure out how to save the data and also the arrow keys don't seem to work 100% of the time which is weird. Thanks, Core2idiot
Having reliable BlueTooth connectivity is essential. The first section of README_ScoutDataEntry2010.txt is devoted to a discussion on different BlueTooth service managers. I've had the best luck with BlueSoleil, specifically version 2.7.0.35 - it works well with both XP and Vista. I haven't tried it with Windows 7.
Data entry instructions can be found here: http://www.nventivity.com/Scout2_Instr.pdf. Because we're using the same arrow keys to count shots and made shots, you have to tilt the wiimote to the left or right to differentiate betwen the two. There's a dead zone between them, so you have to tilt one way or the other.
For BRC (ball re-entry control), turn the "button-side" of the wiimote so that it's vertical (rotate about the long axis) and press the < button (in the orientation shown in the pdf).
To save match data, advance to the "Confirm Save" screen, hold the trigger and give the wiimote a firm shake.
  #77   Spotlight this post!
Unread 15-02-2010, 21:35
Chris is me's Avatar
AKA: Pinecone
Thumbs down Re: Wiimote Digital Scouting System
It would be cool if you could use the LEDs on he Wiimotes as indicators as to whether or not they are tilted enough.
  #78   Spotlight this post!
Unread 15-02-2010, 22:43
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Yeah, that would be a nice improvement.
I wonder how many mistakes scouts make using these. The problem is that the scout may not know he made a mistake ("Did I tilt it enough?").
I think it would be interesting to video tape your robot driving for like 10 minutes and keep track of all the statistics using the Wiimote. Then compare the scouts numbers with the video evidence. If there is any significant difference between the scouts average and the actual number from the video evidence, I would be wary of using this system.
  #79   Spotlight this post!
Unread 15-02-2010, 23:08
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Or use the simulator I described in post #75 to approximate a real robot or match - The simulator records matches for later reviews.
  #80   Spotlight this post!
Unread 15-02-2010, 23:11
XaulZan11's Avatar
FRC #1732
Very true. That would actually work a lot better.
When I saw that 'gblake' was the last poster, I thought, "I'm sure he's is going to propose using 5th Gear...why didn't I think of that...". And sure enough, I was right.
  #81   Spotlight this post!
Unread 02-03-2010, 01:48
PICgnosis's Avatar
AKA: Karen Suhm
Hi, everyone.
Thank you for your feature requests. Rev 1.0.0.1 of the Wiimote Data Entry software is now available at www.nventivity.com/wiimotescout2010_R1.0.0.1.zip. No changes were made to the DB Analyzer.
Included in this release is a Tilt Indicator which may be enabled via a checkbox at the top of the screen. This feature is, by default, left off because the additional monitoring and feedback reduces the responsiveness to user input. It isn't much, but it is noticeable.
When enabled, LED tilt indicators work in Autonomous and Teleop Modes. LEDs 1 and 2 turn on in when tilted enough to the left to record Near, Middle, and Far shots. LEDs 3 and 4 turn on when tilted sufficiently to the right to record Near, Middle, and Far goals. In Teleop mode, all LEDs light when tilted up enough to record ball re-entry control.
A request was also made for compatibility with 1024 x 768 resolution so Rev 1.0.0.1 includes additional support for this display size.
Good luck to all teams at the upcoming regionals!
  #82   Spotlight this post!
Unread 28-03-2010, 07:55
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
Hi,
I saw this scouting system in action at the Virginia Regional and would like to try it at the North Carolina Regional. Does anyone have a database from the Va regional they would be willing to share?
I have downloaded the files and am able to attach a wii remote.
I would like to enter match information so I can play around with the system. I have not been able to do so. The files at the blue alliance have results in them, should they still upload?
Also I tried entering data by hand, but it doesn't stay.
So the only thing I have bee able to do is enter match and team numbers from the wii remote, do I have to do that for each match from each remote?
Thanks,
Jon
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
  #83   Spotlight this post!
Unread 10-02-2011, 14:29
VRC Coach
AKA: Jon T
Does anyone know if this system will be available for 2011?
Jon Thompson
Coach
NASA Knights
  #84   Spotlight this post!
Unread 11-02-2011, 00:04
PICgnosis's Avatar
AKA: Karen Suhm
Yes, it will be available.
We have a list of parameters and would like to start a discussion on button assignments. I don't have the list in front of me - I can share it tomorrow morning.
Thanks for asking!
  #85   Spotlight this post!
Unread 11-02-2011, 00:47
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
You guys get major props, this thing looks amazing. Hopefully we can use it at the Competitions we compete at. i can believe that you guys actually created this.
  #86   Spotlight this post!
Unread 11-02-2011, 08:16
AKA: Pinecone
This is a great system that served 2791 well at our second regional last year.
This year I don't foresee us using it though, not because of any fault of the great software, but because for this game IMO the easiest way to scout is to have a paper representation of the scoring rack to draw on.
We'll see - this could make a GREAT system for scouting minibots. It's literally a stop watch. Click to start, click to stop.
  #87   Spotlight this post!
Unread 11-02-2011, 08:19
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
This is a great scouting sheet good job you guys. Now you are going to make one for 2011?
  #88   Spotlight this post!
Unread 12-02-2011, 01:11
PICgnosis's Avatar
AKA: Karen Suhm
Okay, here's our working parameter list:
Setup
Team number
Robot field position
Autonomous
Attempted top
Attempted middle
Attempted bottom
Made
Spectacular
Teleop
Defended
Attempted top
Attempted middle
Attempted bottom
Made top
Made middle
Made bottom
Tipped over/idle
Spectacular
Endgame
Defended
Minibot deployed
Minibot reached top
Spectacular
Match end
# Penalties
Minibot place
All actions are time-stamped, so if minibot deployed and reached top are pressed in real time, we'll have an approximate time for the minibot to climb the pole.
We're thinking of keeping the same orientation as last year and using ^, >, and v for attempted top, middle, and bottom. Made top, middle, and bottom would be a combo of 2 + ^, >, and v. Tipped over/idle would be upside-down + 2 button.
Spectacular = trigger + hold vertical + pull down. Advance = A, previous screen = trigger + A. Other tentative button assignments will follow shortly.
Any suggestions on parameters and/or button assignments are welcome!
  #89   Spotlight this post!
Unread 12-02-2011, 06:14
AndrewD's Avatar
AndrewD AndrewD is offline
Programming/Electrical Mentor
AKA: Andrew Dolio
FRC #1243 (Dragons)
AndrewD is an unknown quantity at this point
Originally Posted by roboraven15 View Post
i was told that controlling the robot with wiimotes was a bad idea
It wouldn't necessarily be a bad idea...it just takes a bit of work.
____________________________________________
FRC Team #1243 - The Dragons
  #90   Spotlight this post!
Unread 13-02-2011, 09:11
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
when would this be available for 2011?
pic: Wiimote Scoring System-!Nventivity Team 842 falconmaster Extra Discussion 8 25-03-2009 16:07
Web based scouting system (498-Scouting, v2) Nibbles Scouting 6 08-03-2009 21:48
pic: Digital Scouting Data review falconmaster Extra Discussion 8 29-04-2008 10:22
pic: Screen Shots of Team 842 Digital Scout System page 3 falconmaster Extra Discussion 4 31-03-2008 14:11
Nventivity Digital Scouting System now available! falconmaster General Forum 7 01-11-2007 15:22
