Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 02-03-2010, 07:54
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Wind River Workbench Not Loading
Originally Posted by Travis Hoffman View Post
No takers, eh?
Well then, how about this - how do you completely UNINSTALL Wind River Workbench - clean the registry, start from a clean slate? There is no option under Add/Remove programs, nor any other shortcuts that I can see.
I get the feeling that some file or setting is corrupt and needs banished to PC hell before this thing will be fixed....
There should be a directory named 'uninstaller' under c:\WindRiver.
Inside, should be 3 to 5 other directories that contain individual uninstallers (compiler, vxworks, board support, etc.).
You need to run each, in no particular order.
AFAIK, Workbench doesn't infest the registry, so you shouldn't need to worry about that.
Look in c:\Documents and Settings\<your username>.
If there are any files or directories that are obviously Workbench related, delete them.
Look for 'workbench*', 'wr*', etc..
Finally, delete c:\WindRiver.
Note that it is safe to just skip the uninstallers and blow away c:\windriver, but people tend not to believe me when I tell them that.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Obscure Wind River Workbench Problem {td} C/C++ 16 21-01-2010 10:11
WPI update for Wind River Workbench deletes wizards? correnos Technical Discussion 0 16-01-2010 10:08
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Teams happy with Wind River Workbench? gvarndell C/C++ 59 28-07-2009 21:13
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
