Go to Post "So we have an arm, and the pot on it tells how high we are... ...and then we know how high we want to be... ...and if we're not high enough we go higher." (I have to leave the room, we're all laughing too much.) - demosthenes2k8 [more]
Unread 02-03-2010, 08:02
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Re: FIRST Teams discount $5 off each Enersys np18-12, call in orders only
One reason the ES17-12 is cheaper is because it is a 17 a/h battery rather then a 18 a/h battery.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 02-03-2010, 08:08
REVving up for a new season
FRC #2848 (All-sparks)
actually the new battery spec is 17.2 A/h
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 02-03-2010, 08:39
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
hmmm...so if you round 17.2 you get 18
New math !!
Ed Barker
Unread 02-03-2010, 09:23
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
From what I heard, the old batteries were also 17.2AH. They were just labeled 18AH because of "rounding" (aka marketing =P).
Of course, I could be wrong...
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 02-03-2010, 21:48
DonRotolo's Avatar
Back to humble
FRC #0832
Not exactly a scientific survey, but:
We tested all our batteries in perparation for the NJ regional.
All had been fully charged, and allowed to rest 48 hours to bleed off any surface charge. The test was connecting a 1 Ohm, 125 Watt resistor across the battery and reading the voltage at 60 seconds. (We used a main circuit breaker and careful wiring to ensure safety.)
A 2007 and a 2009 battery had an end voltage of 12.46 volts
All the rest (2007/8/9) had an end voltage of 12.25 volts (within 0.03V)
The 2010 battery had an end voltage of 12.16 volts.
To me, it means that the internal construction of the 2010 battery is not as well suited to high current discharge as the MK batteries.
But, of course, a sample size of 1 is not a valid test.
Unread 02-03-2010, 23:49
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Don - we are using a CBA II for the first time this year also. I also note better capacity from MK batteries, but I have only tested 1 of the new batteries also, and I am new to using the CBA II.
Unread 03-03-2010, 20:22
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Originally Posted by Karthik View Post
Don,
Not sure how Alex did it, but we were only able to get that price on the phone. The MK rep was very helpful and their lead times were short. We had our batteries in less than a week.
I will vouch for this and all the other people who went with MK this year - ours were $37 and free shipping from LA, so they took 2 days to get here. MK wanted to refer us to a local distributor, but when we told them that we were a FRC team, they handled the order directly.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Elite (invite only) FIRST teams CraigHickman Team Organization 78 18-11-2008 22:27
# of Teams in each state jacob07 General Forum 19 05-12-2006 09:33
FVC Teams: Call for Proposals - Fourth Annual 2007 FIRST Robotics Conference KathieK FIRST Tech Challenge 0 04-12-2006 20:01
parts discount in NH/MA for any teams kelsey General Forum 0 17-02-2004 23:41
