Go to Post An explanation of the reasoning behind design decisions will almost always result in a more thorough understanding of the solution than analysis alone can obtain. - Travis Covington [more]
Unread 02-03-2010, 01:15
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Simple Mecanum Question
I have been searching around a bit for mecanum drive examples. For what I have seen I can use the Holonomic Drive VI that is included in WPIlib.
If I use the cartesian VI I just need to plug the X and Y axis right from the Get Joystick and it should work?
Searching has been providing me doubts
http://www.chiefdelphi.com/forums/sh...ad.php?t=82498
Specially that topic...
Unread 02-03-2010, 01:55
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Simple Mecanum Question
Some of the posts in the thread you linked to were likely made before the Holonomic - Cartesian VI was released. That VI was only included in the latest Labview update. You can see users discussing it at the end of the linked thread.
Unread 02-03-2010, 07:01
You need to decide how you will control the robot's rotation. If you use a separate joystick just for that, or if you have a joystick with a "twist" function, then the X and Y axes are all you need for speed/direction control. The thread you referenced has an example of "tank drive with strafe" control, which is another way to do it.
Unread 02-03-2010, 10:08
AKA: Yamil Asusta
Oh well... So if I have 2 joysticks I just plug X and Y from one joystick to the corresponding X and Y in the VI and I plug any of the axes from the second joystick in rotation and it should work perfectly?
I remember trying that and motors didn't move...But when I changed to arcade drive...they did.
Also, if I plug in the gyro into the cartesian VI it would let me have something similar to a driver oriented drive?
Unread 03-03-2010, 08:31
AKA: Yamil Asusta
No love ?
Simple question on MPLabs itsme Programming 7 20-01-2007 00:05
Quick Simple Question ImmortalAres Programming 8 17-06-2005 13:08
simple joystick question vexingspector Programming 5 19-02-2005 18:55
simple question... answer it archiver 2001 1 24-06-2002 01:02
simple engineering question Ben Mitchell Technical Discussion 2 07-11-2001 07:50
