Go to Post The few people who don't ever make mistakes are the same people who simply don't do anything. What people do after they make a mistake tells others what they are made of. - Andy Baker [more]
Unread 02-03-2010, 11:43
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
AM FP Planetary Gearbox with CIM
Can anyone fill in the blanks as to how you mount a CIM onto the AM FP Planetary gearbox? After you bore our the sun gear how do you prevent the CIM shaft from slipping? Thanks.
Unread 02-03-2010, 12:04
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: AM FP Planetary Gearbox with CIM
Are you trying to put a CIM on an AM-0002?? That item supposed to make an FP emulate a CIM. There are other planetary gearboxes intended specifically for CIM's.
Regardless, I believe that you would need to broach a .125 keyway in the enlarged bore of the sun gear (if there is room) to keep it from slipping on the CIM output shaft.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 02-03-2010, 12:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Isn't that a 2 mm keyway on an 8 mm shaft?
The AndyMark planetaries intended for CIMs are the GEM series.
Unread 02-03-2010, 12:19
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
we bored out the gear and pressed it onto the cim shaft (no key, pin, set screw). Haven't had any problems yet.
Unread 02-03-2010, 12:21
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
There are many teams who mount CIM's on AM Planetary's. You do need to purchase the correct spacer and gear from AndyMark but it looks like the spacer is out of stock.
Unread 02-03-2010, 12:25
ADZDEBLICK's Avatar
If i recall correctly, all we had to do was flip over the planetary cap, mount the cim to it, and trim down the cim shaft after the gear was on.
Unread 02-03-2010, 12:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Can the AM planetary handle the torque output of a CIM under load? I would presume that using this setup in a drive or winch may be attractive due to weight, but I worry about the longevity of the tranmission.
GitHub
Unread 02-03-2010, 13:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Chris is me View Post
Broaching a keyway is probably the easiest way to make it work at this point if there's room. 2mm keyway, 8mm shaft because CIM shafts are metric..
You can't broach the pinion. There's already only like .030 of wall thickness between the root of the tooth and the bore for a press fit.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-03-2010, 16:05
FRC #2791
Will a press fit work?
Unread 02-03-2010, 16:17
ADZDEBLICK's Avatar
we haven't noticed any issues with our press fit. Your other option is edm the gear so it has a built in key or DD.
Unread 02-03-2010, 16:21
AdamHeard's Avatar
Lead Mentor
It's doable, and not that hard of a process. This post describes what we did; you could easily do it without motor dis assembly to cut the shaft short.
Are you sure the CIM needs the extra reduction to work? I thought the early math showed the gearbox juuuust worked without it, but I'll bite. There used to be instructions on the AM site.
This is definitely possible, my old team's done the mod. It's a nice way to add a little more reduction to a CIM based power system without needing to change things up too much, which is exactly what the team needs. This has absolutely been done before more than once, AndyMark's website claims you can, etc. etc.
Broaching a keyway is probably the easiest way to make it work at this point if there's room. 2mm keyway, 8mm shaft because CIM shafts are metric. I don't know if that can be done. AndyMark sells a 15 / 32 gear that interfaces with the CIM that will work if the broach doesn't. After the gear's all set and the spacer fits right (which has to be made since AM doesn't appear to have it in stock), trimming the end of the motor shaft is all that should be needed.
I don't remember every step of the process in detail, so if there's more trouble I'll bounce an email down.
Not to pick on you specifically, just an example.
I've seen many, many people speculate on processes they do not know and are making pretty wild guesses. Broaching a keyway in this would simply not work.
If you post a technical answer on chief, you better be sure it's valid. People will read your post, and many will take it as fact and not know better.
Unread 02-03-2010, 18:13
Cory's Avatar
AKA: Cory McBride
There is no way to put any sort of keyway into the pinion. It does not matter how you put it in-there simply is no material with which to do it.
2001-2004: Team 100
Unread 02-03-2010, 18:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm curious if Loctite 680 would hold. I've played with it before, holding a gear on a shaft, and it took some rather large channel lock pliers on the gear, with the shaft in a vise, , to get it to slip on the shaft.
Unread 03-03-2010, 09:08
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
This is one of those cases where I put something up on the AndyMark site to make it available, and forget about it until people start asking questions. Sorry about this lack of communication.
1. The CIM Sun Gear is available. The bore is sized to be a press fit onto the shaft of the CIM Motor. No fasteners are needed. Loctite will help secure this to the shaft, but it is not required.
A press fit in this situation is acceptable, as this is a high rpm, low torque location.
2. We don't have the CIM Spacer finished yet (our mills have been very busy with higher priority things). The intent of this part is to space the CIM Motor away from the AM Planetary gearbox so that the CIM Motor shaft does not have to be cut off. If you don't mind cutting off the CIM Motor shaft, then no spacer is needed.
3. The cap of the AM Planetary will need to be turned over during assembly in order to make this work. You must attach the cap to the gearbox, and then attach the CIM Motor to the cap. No alteration to the cap is needed in order to make this work.
Essentially, while using this CIM Sun Gear, the only thing you have to do to add a CIM Motor to the AM Planetary is slice off the CIM Motor shaft after the gear is pressed on.
Let me know if you have any further questions.
Sincerely,
Andy
Unread 03-03-2010, 09:18
Are you recommending that the pinion be pressed onto the motor shaft while the shaft is still in the motor? I wonder if the motor bearings are designed to withstand such an axial load without sustaining damage... especially since small machining tolerances for the press fit can result in large variations in required press force.
If the shaft is not removed from the motor, a shrink fit might be a safer approach.
CIM motor with AM planetary Ice Berg Motors 14 11-03-2009 15:56
Cim/planetary gearbox torque?? Bruceb Motors 3 08-02-2008 11:01
AndyMark CIM Planetary Gearbox Torque Specs Needed KTorak Technical Discussion 4 17-01-2008 18:53
Alternative to CIM with 12:1 GearBox Daru Motors 12 17-01-2007 14:45
Gearbox that can be used inline with a CIM bombadier337 Motors 3 11-03-2005 22:05
