Re: Yet another camera question.
Are there any other alternatives to finding the ball besides finding it on the carpet?
Could you please restate your question? It is vague and confusing enough that you may not get a useful response. This is the perfect example.
My apologies. I'm currently using the default camera code that was in the camera project. I didn't change any of the tracking code and whatnot. The code doesn't correctly pick up the soccer ball. It picks up portions of the ball here and there, but it's not consistent enough to run an effective autonomous mode off of. Are there any other ways I can change the camera tracking code so it picks up and locks onto the entire soccer ball? This is pretty important, seeing as how all our autonomous mode hinges on the camera working. I've seen some teams use the camera effectively, but I haven't seen any code that works 100% of the time.
I see (no pun intended). You may want to look at what Greg said above to answer your question and work to implement alternative solutions. For example, though tracking a ball is rather difficult, locking on the target is fairly effective. So the next problem is to find the ball in autonomous. So you may not be able to see it, but your team has all the control on where to place balls before the game begins. In other words you will know how far the ball is from your starting position when you begin the match. If you can't track distance (no encoder or accelerometer), then you can try timing, which may be effective enough.
Good luck! |
It's not designed to. The default camera code tracks the target not the soccer ball. We didn't try tracking the soccer ball, but had success with the target. Our camera is mounted too high to be useful for the soccer ball anyway.
| Yet another camera issue | adamdb | Programming | 13 | 26-05-2010 09:08 |
| yet another No Camera Images on Dashboard thread | oddjob | C/C++ | 11 | 29-01-2010 20:53 |
| Yet another Camera thread... | Pancake | C/C++ | 2 | 26-01-2009 11:42 |
| yet another joystick question | Stormhammer | Rules/Strategy | 2 | 19-01-2004 10:10 |
| Yet another illustrator question | ryan_f | Computer Graphics | 3 | 02-09-2003 16:10 |
