Go to Post SWARF is evil! - Al Skierkiewicz [more]
Unread 02-03-2010, 15:29
cattart cattart is offline
FRC #1155
cattart is an unknown quantity at this point
Last years soleniods
I was wondering if we could still use the solenoids from last year? I did not see anything against them in the rules so I am just making sure.
If we are, does anyone know where I can get the proper documentation to show to prove that they are legal at the competition?
Thanks.
Unread 02-03-2010, 15:32
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Last years soleniods
This thread talks about them SMC for 2010
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 02-03-2010, 16:25
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Thanks.
Do you mean the solenoids that were about the size of a deck of cards (Festo brand I think)?
I hope so because my team is using them (or planning on using them).
On the subject of those solenoids, does anyone have a link to a spec for them? I have been told that they used 12V but I would feel better if I saw it in writing. There is also that matter of "125 psi rating" from the rules that we have to deal with.
Joe J.
Team #88, TJ2
Unread 02-03-2010, 16:33
Joe,
Simple answer is yes.
<R33> COTS items from ROBOTS entered in previous FIRST competitions or COTS items that are no longer commercially available may be used under the following conditions:
A. The item must be functionally equivalent to the original condition as delivered from the VENDOR (e.g. a part that has non-functional label markings added would be permitted, but a part that has device-specific mounting holes added would be prohibited), and
B. The item must satisfy ALL applicable 2010 FRC materials/parts use rules.
Unread 02-03-2010, 16:38
2009 Festo KOP solenoid
I had a better spec around here somewhere, but I don't know what I did with it...
Unread 02-03-2010, 17:54
AKA: Dr. Joe
FRC #0088 (TJ2)
Thanks guys! My team would be lost without the help.
Cheers,
Joe J.
Team #88, TJ2
Unread 02-03-2010, 21:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Joe, make sure you have spares. Of the six I've checked out from prior years, 2 had internal leaks, either through the exhaust port, or they bled air between ports. Also, although they look the same, at some point there was a change in wiring, we had both types, A & B.
pic: Team 241: This Years Bot Lifting Last Years Bot Dantvman27 Robot Showcase 3 21-02-2007 07:04
Last years versus this years trans. ratios de_ Motors 4 12-01-2006 13:56
Last years robot archiver 2000 2 24-06-2002 00:21
Last years bots archiver 2001 13 23-06-2002 22:26
