Go to Post A robot with hands would be cool! - Koko Ed [more]
Unread 02-03-2010, 14:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Cordura - Which side out?
For those of you who used the actual recommended Cordura, and bought it on a roll, which side did you put facing outward? The inside of the roll or the outside? It's very strange how both sides drastically change color in different lighting conditions and viewing angles.
Unread 02-03-2010, 15:44
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Cordura - Which side out?
The uncoated side it what we put on the outside.
I think the coating would stick to the coating on other bumpers, and just doesn't look as good.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 02-03-2010, 17:00
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
I am pretty sure that the coating is important for the protection of whatever you put on the inside of the cordura. We also tested this because we had the same question. We tried to stab both sides and the coated side was stronger in our tests. I don't think that the coating would stick to other robots either. But I am not entirely sure about that. If you want 100% accurate information, you should probably contact the cordura provider that you bought from.
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 02-03-2010, 17:10
The more I look at it, I'm putting the side that faces the inside of the roll, as the outside of the bumper. I think they roll it this way to protect that surface during transport. Also, I think it looks better this way (at least in my terrible lighting here). I think the side I'm putting out is this "uncoated" side you speak of.
Unread 02-03-2010, 17:31
Onward through the fog.
Cordura is a durable tough fabric. The key word is fabric. I understand that we are using it for bumpers, but I would put the fabric side out with the team number on it, and the slick side in towards the pool noodles.
I'm including a link to Cordura, so that you can see other uses for tough fabric, such as luggage. It also shows a close-up of the weave of the fabric on the home page.
Jane
Edit: I just called one of the companies to confirm what I am suggesting. The slick or 'coated' side goes to the inside. The woven fabric side is the 'right side out'. In other words, if we were making a jacket, the coated side would not be the side that people see when we wear the jacket. Have I totally confused you? If so, my apologies.
~ Helen Keller
(1880-1968)
Last edited by JaneYoung : 02-03-2010 at 17:53. Reason: confirmation from fabric company
Unread 02-03-2010, 18:20
Jane
Thanks Jane. I've got it going the right way, that confirms it for me. I guess my light here is so bad that I really couldn't tell at first.
Unread 02-03-2010, 18:59
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
I didn't even look at it until i have both sets covered and you guessed it, I put one set with coating in and one set with coating out. Looks better with coating in. Too late to change it now.
Unread 03-03-2010, 08:59
There is no rule on which side faces out. The smoother side is usually glued to a backing material when used for luggage.
Unread 03-03-2010, 11:33
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Our bumpers feature the coated surface out. This gave them a nice shiny finish and some specific bumper properties that we wanted.
I concur with Al. There is no rule. And therefore either way is ok.
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 03-03-2010, 13:11
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
typically they are shiny side out
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 03-03-2010, 18:19
The shiny side is easier to paint, or so I have heard.
Unread 03-03-2010, 18:32
The Megan 2207's Avatar
The Megan 2207 The Megan 2207 is offline
FRC #2207 (Prime 329)
The Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really nice
I have found that the non-coated side looks better, works better with paint (it doesn't chip as easily), and doesn't collect sawdust as much.
Unread 04-03-2010, 01:47
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Also, for teams that intend on sliding up the tower during the finale, think about friction properties...
pic: I'm one of 2 people to get Out of the PARC which was a surprise for me =] mtaman02 Extra Discussion 3 11-05-2009 13:46
Cordura fabric vannade General Forum 0 10-01-2009 10:02
Does the trailer have to be able to move side to side? eNyoron General Forum 1 04-01-2009 21:57
Cordura Covering Question (Bumpers) Iceman1330 Technical Discussion 8 07-02-2008 20:57
Which Side are you On? George A. Chit-Chat 16 24-05-2005 21:46
