Go to Post (Respecting a decision) != (Agreeing with it) - dtengineering [more]
Unread 03-03-2010, 00:26
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Re: Extending before finale?
I think I found an answer to my second question while browsing a different section of the Q&A:
http://forums.usfirst.org/showthread.php?t=13730
As defined in Section 6.2.4 of The Manual, the TOWER includes the base and the pipe superstructure. The PLATFORM and the TUNNEL are features of the base, and are therefore part of the TOWER. The carpet under the TOWER is not considered part of the TOWER.
So, because the PLATFORM and TUNNEL are a part of the base, and the base is a part of the TOWER, touching the PLATFORM or TUNNEL means you are touching the TOWER which means you are then able extend to FINALE CONFIGURATION before the FINALE starts. Right? >_>
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Extending IR board connector wires 7-11number1 Electrical 8 14-01-2008 21:49
Extending objects Booger Inventor 10 14-07-2006 13:04
height violation while extending gondorf Rules/Strategy 13 20-01-2006 08:33
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
pic: Vex before extending Not2B Extra Discussion 5 17-04-2005 22:01
