Re: Gyro Wiring?
You set the sensitivity (usualy called gain) in software. The base gain for the 2010 KOP gyro is .007 volts/degree/second. In labview, one of the terminals on the open-gyro block is gain, and you can just wire a constant of .007 to it.
However, I believe that the latest labview update made the default gain .007 to match this year's gyro, so if someone can confirm that you may not need to worry about any of this. |
Re: Gyro Wiring?
Until next year when your old robot code stops working because you used a default that gets changed periodically...
| Wiring Gyro | PingPongPerson | Electrical | 1 | 11-02-2010 21:27 |
| Gyro wiring? | Phoenix Spud | Electrical | 7 | 12-01-2009 13:58 |
| Help: wiring ADXRS300EB Gyro Eval Boards | de_ | Sensors | 3 | 18-03-2008 22:21 |
| 2003 Gyro Wiring Harness | DukesAZ | Electrical | 3 | 03-02-2005 18:20 |
| 2003 Gyro Wiring Harness | DukesAZ | Technical Discussion | 3 | 03-02-2005 18:20 |
