Go to Post FIRST is just a single step in a multi-step process. Rome wasn't built in a day, and neither are solutions to the world's problems. - Tim Baird [more]
Unread 03-03-2010, 06:13
azraimd azraimd is offline
FRC #1234
azraimd is an unknown quantity at this point
need help using MPLAB programming....
can anybody help me to give me an example robot programming using MPLAB for automatically pick and place robot??
here my email:iarza85@yahoo.com
Unread 03-03-2010, 07:01
Electrical Engineer
Rookie Year: 1995
Re: need help using MPLAB programming....
MPLAB was used as a programming environment for FIRST for many years. A search of these forums will yield many discussions and code fragments on the subject.
Also, Kevin Watson kept an excellent code repository here.
Since MPLAB is no longer used in FIRST, you will not find much recent info here.
I assume you are searching in support of VEX. If so, you may want to search here as well.
Mike Betts
As easy as 355/113...
Unread 03-03-2010, 09:28
FRC #1234
can u give me coding for program PIC16f877
Unread 03-03-2010, 14:35
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
As [Mike Betts] said, you might be disappointed by the level of support for PIC devices you find on these forums in current times.
I'd try posting in Microchip's forums instead.
Good luck,
--Ryan
FRC 766, 2015-, Mentor
MPLAB PROGRAMMING PLEASE HELP!!! cstringer Programming 6 20-01-2008 13:49
I need help pls!!I want to download MPLAB 7.2 Krupalkavathia Programming 5 22-03-2007 02:41
MPLAB Help, programming and compiling RedOctober Programming 2 23-12-2005 17:46
Need Mplab help ASAP !! L33T-meh- Programming 3 03-02-2004 21:39
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
