Go to Post it doesn't matter so much why i joined [FIRST], but that i stayed :D - sure_smile [more]
Unread 02-03-2010, 15:10
Andy_Manu Andy_Manu is offline
FRC #2037
Andy_Manu is an unknown quantity at this point
Playing with old RC
Hello
This is my first year doing robotics and I am trying to program an old robot controller from 2007 and i have no idea how to do it.
I got a .hex file i made with easyc pro with a tutorial for driving in arcade mode.
I also have the 2007 master code i downloaded from http://www.ifirobotics.com/rc.shtml#Programming
but as there are 2 RC one for the robot and one for the driver station i do not know what to do
I have looked for guides to do it but I didnt find anything
Any help will be awesome
THANKS
Unread 02-03-2010, 15:18
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Re: Playing with old RC
Originally Posted by Andy_Manu View Post
Hello
THANKS
The RC that isn't lights is the RC that you'll use in the Driver Station!!
And the other, you'll use in the robot!
You should connect the FRC of the robot via DB9 cable in your computer, open MPLab, select C18 compiler and make download of your hex file!!!
Unfortunatelly, I don't know about easyC
PS: I miss the old FRC =/
Unread 02-03-2010, 15:44
FRC #2037
I know which rc goes where
one question i have is if i have to load the program in both rc or only in the robot one?
Unread 03-03-2010, 14:51
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Check around IFI for a "programming guide".
You only program the controller goes on the robot. You only put the master code in once, then your user code everytime you change it.
You download code while connected with DB9 cable using IFI downloader. Its a separate application. You press the programming button before you send it. Press until the program light comes on then release.I think IFI loader has a menu item to download master code.
Thats all I remember off the top of my head.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 03-03-2010, 15:08
FRC #2037
thanks you helped me a lot
Unread 06-04-2010, 04:02
offshore coders offshore coders is offline
Junior Member
AKA: Pho Hue St Vietnam
None #0057 (Chief)
Rookie Year: 1986
offshore coders is an unknown quantity at this point
Thanks for sharing .
Playing Mario Tune with RC Car Kingofl337 General Forum 22 20-04-2008 01:18
pic: Playing I Spy with 195 Tom Bottiglieri Extra Discussion 10 26-02-2008 19:52
Playing with our robot with a TV remote DarkFlame145 Robot Showcase 9 13-01-2008 23:42
Playing with the Content Center KnightOfIvory Inventor 1 29-01-2006 08:03
pic: Arefin playing with my toys Tytus Gerrish Extra Discussion 13 09-10-2005 23:28
