Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 03-03-2010, 22:19
Bart Bart is offline
FRC #2625
Bart is an unknown quantity at this point
Mecanum Spin
Hey, I'm currently trying to figure out how to change the magnitude of the holonomic drive system. I tried the obvious approach (Changing the first float) however, with out current code, nothing seemed to change at all. Could someone look it over and tell me what they think? We basically want the spin of the robot to be dependent on the value returned by the joystick throttle:
//Stop Button
		if(!joyStick->GetRawButton(3))
			//Turn left
			if(joyStick->GetRawButton(4))
				joanRobo->HolonomicDrive(joyStick->GetThrottle(), 0.0, -180.0);
			//Turn right
			else if (joyStick->GetRawButton(5))
				joanRobo->HolonomicDrive(joyStick->GetThrottle(), 0.0, 180.0);
			//Regular holonomic movement
			else
				joanRobo->HolonomicDrive(joyStick->GetMagnitude(), joyStick->GetDirectionDegrees(), 0.0);
		else
			//Stop all movement
			joanRobo->HolonomicDrive(0.0, 0.0, 0.0);
Unread 04-03-2010, 00:08
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Mecanum Spin
I am not sure which part of your code you said not working. Mecanum drive requires 3 joystick axes. According to your code, you are using one joystick. If that's the case, make sure your joystick has 3 axes. Since you are using the GetMagnitude(), it is computing the magnitude by doing sqrt(x*x + y*y), and the direction is computed by atan2(x, -y). So you should make sure that the Y axis of your joystick is controlling the forward/backward movement, the X axis is controlling your sideway movement. Then for the turn, make sure you are using the correct joystick axis for it. At first, we were reading the twist axis for the turn, but it was wrong. This is because our Microsoft Side Winder joystick maps twist to the Z-axis, not twist or throttle. So make sure you reads the correct axis.
Unread 04-03-2010, 23:08
FRC #2625
Re: Mecanum Spin
Well we're using the standard kop joystick, and our controller is indeed moving the robot properly, what we attempted doing is have it spin using to of the top buttons, and regulate the speed of the spin using the throttle on the joystick.
Unread 04-03-2010, 23:52
mikets's Avatar
Software Engineer
Re: Mecanum Spin
If you want to regulate the spin by the throttle, you should probably doing something like this:
if (joyStick->GetRawButton(4))
    joanRobo->HolonomicDrive(0.0, 0.0, -joyStick->GetThrottle());
//Turn right
    joanRobo->HolonomicDrive(0.0, 0.0, joyStick->GetThrottle());
else
pic: Hot Shot Spin Bar Madison Extra Discussion 5 15-09-2009 15:38
A different spin on things. Matt Attallah Chit-Chat 28 24-07-2006 11:38
Will the tetras spin? SteveO Rules/Strategy 15 20-01-2005 02:36
PUSA and Spin Doctors Jeff Rodriguez Chit-Chat 1 08-08-2003 03:37
Motor Spin Direction archiver 2000 6 23-06-2002 23:43
