Go to Post A game where you don't have control of your robot for long periods of time is no fun (unless, of course you are talking about autonomous :p) - Cody Carey [more]
Unread 05-03-2010, 10:59
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: problem: A Dancing Servo
You should confirm that your robot's chassis isn't electrically connected to ground, a signal line, 12V or a motor lead.
Russ
Unread 05-03-2010, 12:27
Yoel2630's Avatar
Yoel2630 Yoel2630 is offline
FRC #2630 (Thunder Bolts)
Yoel2630 is a jewel in the roughYoel2630 is a jewel in the roughYoel2630 is a jewel in the rough
Send a message via MSN to Yoel2630
Russ
we have
It seems to be some kinda noise on the signal while drawing current.
This happens only when we activate the servo simultaneously with two fisher-price motors which are connected to two Victors
Unread 05-03-2010, 12:50
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Clearly there's a line noise problem. Try twisting up the servo cable, or shielding it, assuming is an EMF problem. Also try plugging it in to a output thats further away from the FP signal.
Unread 05-03-2010, 18:07
Fisher Price motors are notorious for producing "brush noise" which is in effect RF noise. Try separating the servo cable from the power wiring for the motors. If they must cross do so at right angles. Robot rules allow you to add some filtering to the motor and the servo lines.
<R69> A signal filter may be wired across motor leads or PWM leads. For the purposes of inspection and rules compliance, such filters will not be considered custom circuits, and will not be considered a violation of Rule <R54> or Rule <R68>. Acceptable signal filters are:
• A one microfarad (1 μF) or less non-polarized capacitor may be applied across the power leads of any motor on your ROBOT (as close to the actual motor leads as reasonably possible)
• A resistor may be used as a shunt resistor for the PWM control signal feeding a servo.
I would recommend a good quality 0.1 microfarad capacitor across the terminals of the motor rated for at least 100 volts. I would also suggest making the servo cable as short as possible. Radio Shack has a variety of ferrite cores that can be placed on the servo cable that may help as well.
Unread 05-03-2010, 18:14
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Al's suggestion is a very sound one. You can solder the capacitor directly to the motor leads on the motor can itself.
Servo Problem Brian_servant Motors 1 17-02-2010 16:55
Problem with servo control Jake The Man NI LabVIEW 2 09-02-2010 23:23
vex servo problem trigger VEX 3 05-10-2008 23:44
Problem controlling a servo Entropia Programming 2 18-06-2005 18:36
The Problem of the Dancing robot SpaceOsc Technical Discussion 8 10-02-2003 17:44
