Go to Post what the HECK are you guys using there?!?!?! - dodar [more]
Unread 04-03-2010, 22:51
tanguma26 tanguma26 is offline
FRC #3999
tanguma26 is an unknown quantity at this point
Question Solenoids Wire
In our arm we have 3 solenoids that shoot at the same time to raise our arm and i was wondering if we can connect all 3 solenoids to the same relay on the cRio, I have look on the first web site and i could not find anything that said that it was legal or illegal. Have anyone try it.
Please help!
Thank you.
Unread 04-03-2010, 23:05
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Re: Solenoids Wire
Solenoids can be connected to either the solenoid module on the cRio, -OR- to a spike relay...
Per <R49-A> you may connect multiple solenoids to a single spike relay.
I don't see anything specifically disallowing controlling multiple solenoids from a single connection on the cRio solenoid module, however I don't recommend it. That module was designed to support 8 separate output signals, not multiple solenoids per output
hope that helps
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 05-03-2010, 07:44
Re: Solenoids Wire
tanguma,
The NI 9472 module can handle 750 ma per output and a max current for the sum of all outputs is 6 amps.
Unread 05-03-2010, 14:24
FRC #3999
Re: Solenoids Wire
ok thank you guys for your help
Solenoids Rohan_DHS Rules/Strategy 2 04-02-2006 00:11
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
# of solenoids Brawler006 Pneumatics 5 01-02-2004 11:12
Solenoids archiver 2001 9 23-06-2002 23:47
Solenoids turbidum Rules/Strategy 1 09-01-2002 21:26
