Go to Post Since this thread doesn't seem to have quite enough numbers yet, here are some more. - William Frost [more]
Unread 05-03-2010, 18:07
Re: problem: A Dancing Servo
Fisher Price motors are notorious for producing "brush noise" which is in effect RF noise. Try separating the servo cable from the power wiring for the motors. If they must cross do so at right angles. Robot rules allow you to add some filtering to the motor and the servo lines.
<R69> A signal filter may be wired across motor leads or PWM leads. For the purposes of inspection and rules compliance, such filters will not be considered custom circuits, and will not be considered a violation of Rule <R54> or Rule <R68>. Acceptable signal filters are:
• A one microfarad (1 μF) or less non-polarized capacitor may be applied across the power leads of any motor on your ROBOT (as close to the actual motor leads as reasonably possible)
• A resistor may be used as a shunt resistor for the PWM control signal feeding a servo.
I would recommend a good quality 0.1 microfarad capacitor across the terminals of the motor rated for at least 100 volts. I would also suggest making the servo cable as short as possible. Radio Shack has a variety of ferrite cores that can be placed on the servo cable that may help as well.
Unread 05-03-2010, 18:14
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Al's suggestion is a very sound one. You can solder the capacitor directly to the motor leads on the motor can itself.
Servo Problem Brian_servant Motors 1 17-02-2010 16:55
Problem with servo control Jake The Man NI LabVIEW 2 09-02-2010 23:23
vex servo problem trigger VEX 3 05-10-2008 23:44
Problem controlling a servo Entropia Programming 2 18-06-2005 18:36
The Problem of the Dancing robot SpaceOsc Technical Discussion 8 10-02-2003 17:44
