Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
View Poll Results: score's lower,higher or what you expected
higher then I expected 7 4.52%
what I expected 57 36.77%
lower then I expected 91 58.71%
Voters: 155. You may not vote on this poll
Unread 05-03-2010, 18:40
Trevor_Decker's Avatar
Trevor_Decker Trevor_Decker is offline
AKA: Trevor Decker
FRC #3504 (Girls of Steel)
Trevor_Decker is an unknown quantity at this point
2010 week 1 low scores
Is it just me or are the scores lower then you expected?
- Trevor
Team 3504 - The Girls of Steel 2011 - Present
2012 Pittsburgh Regional Engineering Inspiration, and website awards
Team 1743 - The Short Circuits 2009 - 2011
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2010 Won Autodesk Animation Competition
2010,2011 Pittsburgh Team spirit award
Unread 05-03-2010, 18:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: 2010 week 1 low scores
The scores are very low, but are exactly what I expected.
Unread 05-03-2010, 18:52
RaidJTC RaidJTC is offline
FRC #2472 (Centurions)
RaidJTC is an unknown quantity at this point
Yeah, after going to the mini-regional in MN, I figured they'd be around here.
Unread 05-03-2010, 19:01
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Out of the first 43 matches at Bayou, an incredible 29 matches ended up with a scoreless team (X-0, 0-X, or 0-0). With a whopping 7 matches going scoreless. (which is just about 1 in 6 matches being a big fat goose egg for both teams)
It's much much lower than I expected. The highest scoring alliances were 9 points (once) and 8 points (once). It seems most matches ended with a sum score between both alliances to be less than 6, which quite honestly is a little bit of a disappointment.
Unread 05-03-2010, 21:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Where are the Hangers?
The points from Hanging are very very low. I just did an analysis of the Kettering Districts.
There is only 1 hanging robot on average per MATCH. That is right, only 1 robot in 6 is hanging!?!?
Crazy.
Especially when you consider that the average WINNING SCORE is 4.3 and the average losing score is 1.3.
That means that in a typical match 6 robots are scoring 3 goals in 2 minutes and one robot is hanging.
Is it a snooze fest?
Joe J.
Team #88, TJ2
Unread 05-03-2010, 21:56
Tarzan19 Tarzan19 is offline
President of Everything
AKA: Taran
FRC #2345 (Kearney Advancing Robotic Sciences (KARS))
Tarzan19 is a jewel in the roughTarzan19 is a jewel in the roughTarzan19 is a jewel in the rough
Even though the scoring is very low, i was expecting ths low of scores just because teams dont understand the true value of the Coopertition bonuses. Though, this being said, there is no snooze fest going on out there, it is probably the most strategic game in at least 3 years.
Unread 05-03-2010, 21:59
Let's hope it just week 1 cobwebs.
Unread 05-03-2010, 22:01
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Even better question: why are teams playing defense in the qualification rounds?!!?
With the ranking algorithm this year, you are shooting yourself in the foot (ranking wise) by keeping qualification match scores low. W/L records don't matter this year during the qualification rounds!
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-03-2010, 22:13
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
We encountered a team that told us that as an alliance they would play in the spirit of FIRST and win or lose. My only thoughts were that they wanted to advertise as a defensive robot for eliminations. Oh well, we gave them a chance!
1058 PVC Pirates 2016 - xxxx
Unread 05-03-2010, 22:15
Chris is me's Avatar
AKA: Pinecone
If you're not going to be in the Top 8 anyway, you might as well show off your defense.
Unread 05-03-2010, 22:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's the worst I've ever seen it.
Imagine both alliances playing for 2 minutes 15 seconds and not a single robot being able to herd a SINGLE BALL across the scoring line. Not once. It's happening with frightening frequency. Issues I'm seeing:
1. People drastically underestimated the importance of an effective ball magnet.
2. People drastically underestimated the importance of hanging.
3. People clearly do NOT UNDERSTAND the scoring rules and are playing big-time defense, and the teams who DO understand the rules are absolutely running-away score wise.
4. The penalties this year are epic. In one match we saw a bot waved for 12 penalties because their kicker was staying out of package to long - and they continued to kick over and over.
I thought last years game was slow. I stand very, very corrected.
Unread 05-03-2010, 22:34
AKA: Brendan Browne
I don't think teams underestimated hanging. If hanging was a bigger bonus, say 5 points. There would definitely be more hangers. Making a good, reliable kicker that can pump out balls quickly is not worth the sacrifice to hang especially if you can score more than 2 balls in the finale. I don't think it is teams underestimating it, it is just that it isn't worth it.
Unread 05-03-2010, 22:35
AKA: Pinecone
I think people overestimated their own kickers when making this tradeoff. Teams never fail to overestimate their own scoring ability.
Unread 05-03-2010, 22:41
AKA: Brendan Browne
Very, very true Chris!
Unread 05-03-2010, 22:46
hg273's Avatar
hg273 hg273 is offline
AKA: Henry Gordon
FRC #1540 (Flaming Chickens)
hg273 will become famous soon enough
Joe J.
Update from Autodesk Oregon:
Not a single team has hung yet through 61 competition matches
National Robotics Week 2010 April 10-18 RoboMom General Forum 2 12-04-2010 13:09
pic: Team 1322 2010 Robot Start Week 3 joeweber Extra Discussion 14 02-02-2010 18:04
Week 1 High Scores Cuse Regional Competitions 15 01-03-2009 23:09
Predictions Week 4: Bash Fests in Boston, San Diego & Waterloo. Big Scores @ Buckeye Joe Johnson General Forum 51 28-03-2007 12:36
Scores? We've got your scores right here... archiver 2000 2 23-06-2002 22:27
