Go to Post Break Robot. Re-engineer. Repeat! - Mr MOE [more]
Unread 05-03-2010, 20:28
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Autonomous not working
Our auto mode is programed in but it wont start. Its based on time, like from the object that gives match time. I dont know if that would cause it? But parts of it that have nothing to do with match time dont work either. Is there anything special I have to pit in the auto int case?
Unread 05-03-2010, 20:42
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Autonomous not working
Could you post your code? People can only help and find errors if we can see it.
what object?
Watchdog.Kill();
Unread 05-03-2010, 20:43
AKA: Brandon Liatys
Match info. The codes in the classmate locked in our tookbox at the moment.
Unread 05-03-2010, 21:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Sounds like you're using Labview, is this correct?
I'm not sure if they changed this from last year or not, but that "Autonomous Elapsed Seconds" part of the cluster in the default Auto Iterative code was in milliseconds last year not seconds. Had to find that out by probing it while trying to fix a similar issue last year.
Unread 05-03-2010, 21:44
AKA: Brandon Liatys
Still, we have a motor that should run at a set speed that has nothing to do with the time at all. Its just when auto starts, motor should turns and not stop.
Unread 05-03-2010, 21:51
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I would double check that you have set the proper Autonomous to execute in Begin.VI. The default is Autonomous Independent if I recall correctly.
Also, make sure that you are feeding the watchdog appropriately in Autonomous mode.
The best way to debug what's going on is going to be by running your Autonomous on the practice field. Look for errors on the driver station Diagnostics tab. If you don't see any and Autonomous is still not do anything, run your code from a computer instead of deploying it, this will allow you to use probes to see what is happening in your code.
Unread 05-03-2010, 21:56
AKA: Brandon Liatys
Ill stick it on blocks in the pit.
Now wait a sec, were supposed to tell auto to execute in begin.vi? THATS news to me.
How does one do this?
Unread 05-03-2010, 22:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
At the top of Begin.VI is a selector for whether you are using Autonomous Independent or Autonomous Iterative. You need to set this enum to match the mode you put your code in.
I have circled the setting you need to change to use Autonomous Iterative in red in the attached picture. You DO NOT need to modify the two things I have crossed out in blue
Unread 05-03-2010, 22:15
AKA: Brandon Liatys
Thanks a ton. If I cant get it working I'll ask someone there.
Unread 06-03-2010, 21:02
AKA: Brandon Liatys
Thanks, thats exactly what was wrong. Changed it and ran it and the robot almost ran away
Unread 07-03-2010, 00:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Fantastic! Glad I could help, and glad you got your issues ironed out.
Unread 18-03-2010, 20:29
palmyhomebots's Avatar
palmyhomebots palmyhomebots is offline
None #2934
palmyhomebots is an unknown quantity at this point
Lightbulb Re: Autonomous not working
we the palmy home bots have a better solution just do this:
//When channel 5 down the below code runs
if(vexRT(Ch5) > -100)
motor[LTrack] = motor[RTrack] = 0;
motor[LMotors] = 127;
motor[RMotors] = 127;
wait10Msec(400);
motor[LMotors] = 0;
motor[RMotors] = 0;
motor[LTrack] = motor[RTrack] = 127;
wait10Msec(1600);
but you may have a different robot
Unread 18-03-2010, 23:30
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
wait10Msec(400);
motor[LMotors] = 0;
motor[RMotors] = 0;
wait10Msec(1600);
The OP was programming in LV for the cRIO, your code is C for the VEX controller =P
They both work, but porting this code over is more difficult than just re-writing it. (Just a side note, motor power is -1 to 1 now, not 0 to 255 anymore).
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
DIO not working in autonomous. adamdb NI LabVIEW 10 12-02-2009 01:23
Camera Code not Working in Autonomous? Mikesername Programming 6 28-01-2009 10:14
Help Autonomous code not working team550 Programming 5 14-01-2008 10:35
Camera not working in autonomous Roger Programming 9 09-03-2006 07:38
Gyro not working in Autonomous? kaszeta Programming 7 11-02-2006 01:28
