Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 05-03-2010, 22:59
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Ranking
Originally Posted by Collin Fultz View Post
I am personally becomming a fan of this new ranking system. It's really factoring in a strength of schedule into the rankings. In the old system, a 2-0 win was worth the same as a 10-9 win (I know...ranking points...but the W was the most important). Now, a 10-9 win is a HUGE score.
There is an easy way to factor in the difficulty of a match. Take both the red and blue scores (before penalties), add them together, and divide by 2 (or not). There is your match difficulty score. Teams are ranked by win/loss first, then difficulty score. This both promotes scoring and winning.
Unread 05-03-2010, 23:48
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Ranking
Isn't this basically what the old system did? It ranked you by W/L then by opponent's points, so if you were winning high scoring matches, you ranked higher than if you were winning low scoring matches or matches where you scored high but your opponents don't score much.
I'm not saying one way is better than the other, yet. Let's get through a few weeks of regionals and Champs before hashing it out. All I'm saying is that I REALLY didn't like the ranking process going into this morning, but after watching it play out for a day, it's not so bad.
Will there be flaws in any system that uses such a small population of data to "rank" teams? Of course. That's the world in which we choose to compete. I'm just saying it's not as bad as I thought it would be going in.
Collin Fultz
Unread 05-03-2010, 23:53
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
Re: Ranking
I would be a fan of the new ranking system if the matches were higher-scoring. Here is an example of what happened to us:
We won a match 3-2 and were very happy, this was a fairly good match for us. Then, a robot on our alliance was assessed 5 <G46> penalties and the other team 1, causing us to lose 0-1. This means we get 2 seeding points. The other team gets 1 + 6 = 7 seeding points. This is a huge number of seeding points when the matches are usually won 1 or 2 to 0 (we only have around 8 seeding points total). A win due to exorbitant penalties on a good alliance is not a strategic win, and should not be rewarded like this.
Unread 05-03-2010, 23:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Ranking
If the alliance wracked up exorbitant penalties I guess they weren't really so good after all were they?
Moral of the story: Don't get penalties!!
Unread 06-03-2010, 00:04
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: Ranking
Yeah, but Michigan teams still need to win every match possible to quailfiy for states (State ranking points are based on wins/loses).. Kinda throws a monkey wrench into everything...
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 06-03-2010, 00:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Ranking
While Michigan teams definitely have an added wrinkle, don't forget that making the Top 8 is also worth points in the Michigan system.
Being the #8 seed is worth more than 4 wins, and being the number 1 seed is worth the same as 8 wins.
Smoores's Avatar
Smoores Smoores is offline
AKA: Steve Moore
FRC #2272 (Metalheads)
Team Role: Student
Smoores will become famous soon enoughSmoores will become famous soon enough
Re: Ranking
Yeah it seems that after 5 solid hours of live streaming today. A significant amount of teams don"t realize how they should play the game. Blocking hurts everyone, and multiple times people tried bumping robots trying to elevate. But holy cow, THERE WERE SO MANY PENALTIES!!!
Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
2007 Championship Highest Rookie Seed - Galileo
2007 CA Rookie All-Star
2007 CA Highest Rookie Seed
Unread 06-03-2010, 00:30
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Re: Ranking
Yeah, I can't count the number of penalties there were for robots that somehow managed to drive on top of the soccer balls...
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 06-03-2010, 01:27
dtengineering's Avatar
AKA: Jason Brett
Re: Ranking
Well, as was posted somewhere else earlier.... "FIRST finally gives us a game where human beings can understand the scoring system, and then goes and gives us a ranking system that requires a two hour seminar on co-opertition to comprehend."
I get what FIRST is trying to do with the ranking system. I get the fact that Dean Kamen managed to get a patent on it... I've even read the patent (and the many objections the USPTO raised to it)... AND I get the fact that it is the rules, and that FIRST can set whatever rules they want. Even if I think the rule happens to be needlessly confusing, it is still a rule.
But it would really help to get people (who don't geek out over the FRC rules book) interested and excited about FRC if the ranking system could be quickly and easily understood by a person off the street without a lengthy lecture on "changing culture".
Thank goodness the elimination rounds will make sense to people who come to watch them.
Jason
P.S. My sympathies to those who don't "get it". It will all make sense if you watch a four hour retrospective video on the collected speeches of Dean and Woodie. You might still not LIKE it, but at least you'll "get" it.
Unread 06-03-2010, 01:37
Wei Wei is offline
FRC #1885
Wei is an unknown quantity at this point
Re: Ranking
FIRST has made winning or losing a match this year unimportant (for qualification matches). Its how everyone does (including your opponents) that affects your seeding score; not winning or losing. FIRST seem to have set up a version of the prisoner dilemma (game theory). Almost everyone I have talked to at the DC regional (on Friday) is playing this year's game as a zero sum game(my gain is your lost).
Imagine the scoring potential if all SIX robots were working together to score all the points for blue or for red. According to this years seeding formula:
winner seeding points = (winning alliance score - Penalty) + 2*(losing alliance score)
loser seeding points = winning alliance score
If everyone works together and the losing alliance does not have any points, then the winner and the loser get the exact same seeding score.
Where this is not a zero sum game is the number of balls score will be much higher when all six robots are working together then working against each other or the alliance leaving each other alone. Its very easy to move all the balls from the middle to the offense zone if there are 3 to 4 robots in the middle zone. You're more likely to have a robot free to handle a returning ball if the other robots taking a little longer dealing with their current ball(s). With the remaining 2 to 3 robot in the scoring zone, you have a situation where 1 to 2 robots are scoring while the other robot is collect balls to be score. With 6 working robots, the limitation on points will be how fast the human players can get the balls back into play, so that there are no penalties.
Under this strategy, the robots that cooperate the best together get the best seeding scores.
Unread 06-03-2010, 00:09
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Re: Ranking
Originally Posted by Tarzan19 View Post
I understand the rules.
a day of competition made sure of that, it just baffled me that we were stomp and still shoot up 3 ranks, thats all.
the reason you shot up 3 spots was because nobody else played who was ranked above you, you pretty much gained nine points in the seeding match while everyone else didn't play.
I love this new rating system. I still do not comprehend why someone would want to play defense during qualifications, unless that's their outlet to get into the eliminations.
Speaking of that, im going to get a good laugh when those scores are much lower than what we're already seeing.
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 06-03-2010, 07:47
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Ranking
I have declined to comment on the scoring system all year...
So all I have to say is: Any scoring system that ever gives people incentive to score on themselves at ANY point during ANY match needs to be re-evaluated.
What was wrong with the old days when the teams that won got the best seeds? What part of earning your seeding position isn't fair?
Unread 06-03-2010, 08:34
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Ranking
Unless, as posted above, FIRST's intent was to make a game where you aren't true opponents. Before the alliance era, there were games where (as I understand it) you had to work together with the others in the match to maximize your score in that match. If you look at backwards scoring less as "scoring on yourself" and more as "scoring for the greater good of both alliances", then the difference becomes clearer. This game and seeding system can be interpreted as not a strictly 3v3 game, it can also be seen at 6v0.
The highest possible QP comes from a tightly-fought match, but the most reliable QP comes if both teams agree to co-operate and only score on one side.
Unread 06-03-2010, 10:18
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Ranking
True if you could avoid penalties, which teams obviously are not doing
Unread 06-03-2010, 10:33
Onward through the fog.
Re: Ranking
They will figure that out. Or not.
~ Helen Keller
(1880-1968)
Ranking score? jasper.s.jacobs General Forum 6 22-04-2008 08:53
Ranking Points IndySam Rules/Strategy 0 07-01-2008 11:13
Ranking D.Bear Championship Event 4 20-04-2007 16:17
ranking at BEA sburro Regional Competitions 0 07-03-2006 18:47
Ranking database. Josh Hambright General Forum 9 11-03-2003 09:05
