Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Unread 06-03-2010, 20:10
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Not Showing Up To A Match - Seeding Points?
I was perusing the FLR standings, and noticed several teams did not play 10 matches as scheduled:
http://www2.usfirst.org/2010comp/eve.../rankings.html
639 played only 8?
Was this a result of not showing up to a match? I'm assuming this was the case, which means they received no seeding points for the match?
If so, I read a thread about a regional where a team that rarely showed up to matches was ranked 2nd at some point. How could this be the case? Are no-shows being handled differently at different regionals?
Could someone confirm what exactly is supposed to happen to no-shows in terms of seeding points?
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 06-03-2010, 20:19
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Not Showing Up To A Match - Seeding Points?
A no-show receives no seeding points. As in past years all you have to do is send a human player to not be considered a no-show, no robot required.
9.3.6 Seeding Point Exceptions
A SURROGATE TEAM will receive zero seeding points and zero coopertition bonus.
A TEAM is declared a no-show if no member of the team is in the ALLIANCE ZONE at the start of the MATCH; a no-show team will receive a RED CARD for that MATCH.
During the qualification matches, TEAMS can individually receive RED CARDS. A RED CARDED TEAM will receive zero seeding points and zero coopertition bonus.
Unread 06-03-2010, 20:41
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
So if a Human Player is provided, then they still get their seeding points, correct?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 06-03-2010, 20:44
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yep, as long as some member of your team is in the alliance box at the start of the match you will get your Seeding Points. The Human Player is usually the one that gets sent, but they don't have to be.
Unread 06-03-2010, 20:47
Chris is me's Avatar
AKA: Pinecone
I wonder how strategic it would be to miss a match against an alliance that's doomed to beat you if you're partially functioning.
Isn't it sad that the thought even crossed my mind?
AKA: Mr. Lim
Hmm... this year keeps getting more and more interesting.
Things I learned in this thread:
1) NEVER no-show... send someone/ANYONE. The seeding point penalty for no-showing REALLY hurts this year.
2) Have a no-show on your alliance? Probably going to lose the match as a result? No problem... this is the perfect opportunity to "coopertate."
Unread 06-03-2010, 20:50
AKA: Pinecone
Though to be completely fair, this has mattered every year. You wouldn't get a win if your alliance did pull off a 2v3 victory if you were a no show.
Unread 06-03-2010, 20:56
AKA: Mr. Lim
I suppose my point is that this year in a 2vs3 there are strategies you can use to still guarantee pretty good seeding points in a loss - in fact you CAN guarantee as many seeding points as the winning alliance.
In past years there was less incentive to play a 2vs3 because it typically meant a loss.
This year, although 2vs3 still aren't great, if played right, you will still earn very significant seeding points even if you lose - so long as you play it right.
To no-show isn't just walking away from a probable loss, but you're now walking away from very significant seeding points - possibly the same had you won.
To me, that makes the penalty for no-showing much higher this year.
Unread 06-03-2010, 21:22
GaryVoshol's Avatar
Cogito ergo arbitro
Another reason for less matches is DQ's / red cards. They're relatively easy to get this year. 14 of them in 74 matches at Kettering, none were because of no-shows.
(since 2004)
Unread 06-03-2010, 21:48
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Hey, I am here from 639, and the reason we only "played" 8 was because of 2 DQ's (ikr?). The first red card was due to while we were hanging, and touching the tower, another robot bumped us right while our arm was going down, and we hit the two bars under the ball return. Our drive team decided to go for it anyways, and pulled up. Due to this, the ref thought it was intentional, and gave us a red card. The second one was due to our driver raising our arm before finale. He saw another robot doing it (he was touching the tower) and assumed that we were in finale. Sadly, it cost us a yellow, and then a red card due to the first one. Anyways, we were seeded at 27 due to no few losses after the DQs. They also give you NO seeding score, so it killed our qual rank.
Anyways, we were very successful in elimination, scoring five points while the rest of our team lost connection to the field.
Unread 06-03-2010, 23:22
AKA: Pinecone
It's a red card to hang from the "normal" bars on that side of the field, ever.
Unread 06-03-2010, 23:31
AKA: Simon Bohn
Looks like your right; I am not the team expert on rules, but neither was our former driver. I wish that our driver hadn't started our winch
In fact, I dont think that we even knew that that was illegal, lol, although we are usually pretty good with rules (no G46 violations!)
Unread 07-03-2010, 01:50
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I disagree somewhat. In previous years missing a match didn't mean too much for ranks. I remember a match 1766 couldn't make due to robot fixes. After that round of matches, we went up in ranks. I studied the ranks and noticed something. A team that wins 2 and loses 3 is ranked lower then a team that wins 2 loses 2. This means that missing a match you lose would raise your rank even though you'd lose rank points. I realize this doesn't work for this years game...and am disappointed that it was true for previous years. However, it is true. I've yet to hear of a team that has actually used such a strategy due to the ethics of doing it on purpose.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 07-03-2010, 02:03
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Actually this was only true in some instances. Wins were 2 points, ties were 1, and losses were 0. Therefore 2-3-0 and 2-2-0 would both be equal to 4 qualification points. What caused the team with 3 losses to be ranked below the one with 2 losses would be the ranking points (score of losing alliance).
EDIT: Just for clarification, this is about last year, not this year.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 07-03-2010, 02:04
AKA: Pinecone
This wasn't true. You got 2 points for a win and 0 for a loss. Additional losses took nothing from you.
Manipulator not showing rastermon 3D Animation and Competition 3 24-02-2010 11:23
9.3.4 Match Seeding Points theycallhimtom Rules/Strategy 92 25-01-2010 16:18
Changing Rule 9.3.4 Match Seeding Points Valley Raider General Forum 1 16-01-2010 15:49
Match Seeding Points Valley Raider General Forum 2 16-01-2010 14:22
Match Seeding Points Katie_UPS Rules/Strategy 1 09-01-2010 15:59
