Go to Post ...it takes a very special kind of person to equate bagpipes with harps. - Kevin Sevcik [more]
Unread 07-03-2010, 06:55
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Rules, changed by the ref, or correct interpretation?
Originally Posted by alicen View Post
just my two cents, but the design of the goal is a certain way..
in my opinion, if it passes the plane of the goal opening it is scored.....
Wow, that interpretation would have REALLY changed the scores. I saw numerous balls that broke the plane of the goal, but ended up coming back out. At least 33% our autonomous shots did that (gotta adjust that kicker).
Former Mentor Team 1771
Former mentor Team 4509
Unread 07-03-2010, 08:40
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Kettering human players were allowed to use tident to unjam balls. They had one field problem during finals with ball counter. This is what i saw on screen for one team- end of auto=3 then 5 then 7 then 5 then 7 then 9...well their final score was 4. They put a person in each corner after that to count balls. Also it just seemed like the blue side was acting up control wise.
Unread 07-03-2010, 09:36
rspurlin's Avatar
rspurlin rspurlin is offline
AKA: Ray Spurlin
no team (no team)
rspurlin has a spectacular aura aboutrspurlin has a spectacular aura about
I don't think she's talking about balls that break the plane at some point but do not remain in the goal, completely past the plane of the alliance station wall. There is a lip on the ramp that should prevent a ball from rolling back out onto the field.
The real question is whether a ball inside the goal, on the player side of the plane of the alliance station wall should count even if it has not gone through the counter. It would be folly to assume that a head ref that has a GDC member in the building and the Chief Ref (Aidan Brown) as close as her Blackberry would make such a call in a vacuum. Perhaps this is one of those things that no one expected would happen and will be clarified in future updates.
And do adjust the kicker on your bot. Your bot was one of the few that had any chance of scoring while not in the near zone, if not in the goal itself. I think your bot is an example of what everyone had in mind when designing this years game. With the tweaking I know you'll do, not only to your kicker, I expect and hope you will do well at Championships. We'll see you there.
Mentor(2007-2013) - Team 1379 - Gear Devils - Norcross, GA
2010 Palmetto regional Semifinalists, Judges Award
2010 Peachtree Regional Quarterfinalists, GM Industrial Design Award
2009 Palmetto Regional Finalists
2008 Bayou Regional Quarterfinalists
2008 Peachtree Regional Semifinalists
2007 Peachtree Regional Quarterfinalists
Georgia FRC Planning Committee
Unread 07-03-2010, 09:40
rspurlin's Avatar
AKA: Ray Spurlin
no team (no team)
Do you mean that the human player was using the trident to unjam balls on the ball return or in the goals themselves? If in the goals, i can understand why the ball count would be off. The trident could have easily tripped the optoelectronic ball sensor.
We had one incident where a human player hit a jammed ball on the ball return (before it had passed through the return counter) and knocked the ball back onto the field without passing throught he return counter. They earned mucho ball return penalty points.
Unread 07-03-2010, 09:50
FRC #0910
Trident was used in goals but had nothing to do with the missed count. That ten second return rule/function started acting up.
Unread 07-03-2010, 10:07
rspurlin's Avatar
AKA: Ray Spurlin
no team (no team)
do you mean the DOGMA calculation and automatic penalty assessment or the ten second grace after the end of the match when balls could still score? Are the scorekeeper/field power person(s) at your event passing this issue back up to FIRST hq?
Unread 07-03-2010, 10:36
martin417's Avatar
AKA: Martin Wilson
I talked to the head ref about the call. She explained that earlier in the day, two balls had entered the goal at the same time, and got jammed in the goal and therefore the goal was blocked (no robot was present). They decided that it was a field fault and cleared the jam, allowing the balls to score. I agree with that call.
I have doubts about the second case, where the robot was part of the jam-up. Lets suppose the event occurred early in the match, with the robot and balls all jammed in the goal. For whatever reason, the robot can't move (bot broke, bot stuck, or, at the end of the match and time runs out). What do we do now? Free the stuck bot manually while the match is still going? let it stay until the end, and score the balls?
It is my opinion that if the bot jammed itself in with balls, and is acting as a dam, blocking the goal and preventing the balls from scoring, that is a result of robot action, not a field fault.
Unread 07-03-2010, 11:19
rspurlin's Avatar
AKA: Ray Spurlin
no team (no team)
I see your point. Perhaps we will get further clarification and direction on this.
it seems that other regional events allowed the human players to use the handle of the trident between the gap in the rear goal lexan cover and the ball counter to address jammed balls. I am not a fan of this solution, but it might be one more thing to add to our understanding of this years game, for those of us with events still to come.
Unread 07-03-2010, 11:35
martin417's Avatar
AKA: Martin Wilson
All in all, I thought the refs were dead on throughout the day. I even agreed with the red card on my team. From my point of view at the time, our robot's action appeared both intentional and aggressive, and was obviously outside the bumper zone. I would have made the same call. I listened as our drive team made an argument for why they did it, and their argument sounded weak. After the drive team team saw the video we made from the side line, the light bulb went off over their heads, and we all figured out what happened.
When the red bot tipped, their bot blocked the drivers' view, and our drive team could not see our bot. They thought the red bot was resting on top of our bot (it was actually resting on its side). They drove forward and backward in an attempt to free themselves (even though they weren't actually entangled). What it looked like from the side was them backing up and intentionally ramming the tipped bot. It was unfortunate, but it happened.
Unread 07-03-2010, 16:45
well, i can point you back to another rule that states "if a robot is in contact with their tower during the finale period, and the other alliance bumps it, they get RED CARDED" the intention of that rule is that hanging robots won't be destroyed, but non hangers can potentially use that to DQ their opponents.
Can you suggest a scenario where a team's actions can give the opponent a red card?
Unread 07-03-2010, 16:59
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
A robot is attempting to hang during finale, and has just touched the tower. However, a few seconds earlier, during teleop, the opposing team was trying to stop it from getting to the tower. Now, another member of the hanging robot's alliance pushes on the robot formerly blocking the tower, into the almost hanging robot. Red card.
Unread 07-03-2010, 17:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
you can't be pushed into a penalty by the other team.
Unread 07-03-2010, 17:03
rspurlin's Avatar
AKA: Ray Spurlin
no team (no team)
There is a specific rule prohibiting the actions of a team/robot from incurring a penalty on the opposing alliance, but in this year's game, a robot with no ability to hang might be in a pushing match with an opposing robot during finale. If they move into contact with the tower and the opposing robot touches them, technically it could be a red card for interfering with an attempt to elevate (by climbing instead of hanging). It seems possible that you could goad someone into touching you in such a situation. A smart driver should steer well clear of the opposing tower and any robots around it during the finale period.
the trouble begins when you substitute the concept of hanging for the game concept of elevated. Even the ref may jump to this conclusion and not call a penalty in this situation.
Unread 08-03-2010, 02:36
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Here is a smarter situation.
Attempt an end game climb, the opponent backs off, then you rush to the goal with a ball in sight and score.
Then, repeat in later matches.
Unread 08-03-2010, 08:59
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
We had a similar situation at the DC Regional where two balls got jammed in the goal while a robot was trying to score them. The Head Ref decided not to score them since they did not pass the ball counter. Later a GDC member that was present was asked about this and said that the right decision was made in their part. They also commented that the field was designed with the intent that the end of the trident could in fact be used in that gap between the goal lexan cover and the metal frame to unjam balls in the goal. It was also said that they would make sure that this would be cleared up for future Regional events. Although this was nice to know after the fact, I would say that it would have been nice to know this tid-bit of information before hand.
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
SPAM... has it changed your life? (the team or the meat..or both!) Adare180 Thanks and/or Congrats 8 13-02-2007 23:03
Regional-specific rules, etc., and do the referees read the rules? Kit Gerhart Rules/Strategy 53 18-04-2005 08:51
Andy Baker is the BEST REF EVER suneel112 General Forum 8 12-07-2004 01:03
Has FIRST Ever Changed Rules During Nationals? IMDWalrus General Forum 2 08-04-2003 15:29
Interpretation of rules Ben Mitchell Rules/Strategy 1 09-01-2002 19:53
