Go to Post IMO the main idea behind FIRST is for the mentors and students to work together to produce a machine that the students could never have produced on their own. - Tim Sharp [more]
View Poll Results: Should goals scored for the opposition not be counted?
Yes - you should score only for your own alliance. 56 49.12%
No - keep things the way they are. 58 50.88%
Voters: 114. You may not vote on this poll
Unread 07-03-2010, 14:12
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Don't count goals scored for the opposition - Yes or No?
Originally Posted by Lostmage333 View Post
What defines "scored for the opposition"? Redbot kicked a ball, which touched bluebot, and went into the red goal. Who scored? Red who kicked, or blue who touched it last?
I would think that just the presence of the rule would be enough to dispel most teams from following the practice. How much intentional tipping did you see at events this past weekend?
Keep it simple - kick originated from red and entered blue's goal - IF DETECTED by the person assigned to catch it, it doesn't count, regardless of how it got there.
Most intentional scoring attempts from the opposition should be direct, obvious, and easily detectable by the volunteer(s) responsible for tracking them. Discount those. Accidental "deflection" scores and such will not be as obvious and are less likely to be caught. No big deal.
Much like refs sometimes fail to catch penalties, I'm sure some opposing scores would be missed. But the obvious ones should always be caught, and that's the main goal.
How do you tell who "scored"? The scoring system is automated. It eliminates the need for scorers. But wait, now we need people to not only count the goals, but also tell the system which ones are "legitimate"?
Deduct at the end of the game. Have existing refs or additional volunteers keep track. It's not like it's going to be a rampant practice if the rule is placed in effect.
How do you enforce DOGMA penalties now? Must the balls still be put into play in the same timely manner? In that case, scoring for your opponents becomes a means of giving them penalties exclusively? But wait, you cannot cause a penalty. If they don't need to be returned, how do you tell the HP they can take their time with that ball.
No changes to any other rules. HP's return all balls as usual.
One would think any attempts to overwhelm an opponents' HP's would be rather obvious, wreckless, and pointless. This is a non-issue.
So if you really want to fix the problem, I find it more logical to go after its root, and not just patch its branches.
I'm sure many will "go after" the root cause in the offseason. This is an attempt to discuss meaningful ways to address rising concerns THIS season.
Unread 07-03-2010, 16:50
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
The problem with that is that people don't like ambiguous rules. Leave it ambiguous, and you'll get complaints that its not well stated. If you want to put a rule like this, I would think you need to define it clearly.
The intent behind the automated scoring system is that it is exactly that. Automated. FIRST is trying to remove human scoring for this, because that is inherently flawed. Granted, the automated scoring isn't flawless (at least it's better than 08 lap counters), but introducing volunteers to count the scores adds additional complexity.
Another, somewhat unrelated point. Last week, I saw one instance where the defending robot pushed a ball into the goal it was defending (or was pushed and therefore pushed a ball in). How would these be called? Leaving ambiguity in the rules leaves different events to have different interpretations. That causes problems. Adding additional wording results in more rules. Neither is very pretty.
I see it this way. If your robot has a roller that sometimes pulls the balls under the robot, incurring G46 penalties, how would you fix it? Would you try to adjust the placement of weight on your robot to fix it, or fix the roller itself? This scoring for your opponents concept is nothing new. Its a new reincarnation of old concepts. This new reincarnation is more powerful, and probably more widespread, but even if it is a bad concept (which I don't think it is), FIRST is no more likely to ban scoring on yourself than they are to change the ranking system.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 07-03-2010, 18:58
O-H
I didn't want to go here, but...would the following provide clear enough a message?
<G3.14159> TEAMS are not permitted to intentionally score in the opposing ALLIANCE's goals. Violation: PENALTY and YELLOW CARD.
It's a penalizable offense now. Scoring will be conducted in an automated fashion as usual. The referee will penalize one point per infraction, with a yellow card. Do you think teams will bother attempting the practice with such a stiff penalty in place? Most teams don't want to do it anyway. They do it merely as an incentivized reaction to a loophole/quirk in the ranking/seeding rules. Close the loophole, and the incentive is removed.
Then shame on them for furthering all the frustrations and contradictory dilemmas propagating forth at events and in these myriad of CD threads.
If those responsible for permitting these behaviors will not act, it is up to the community to raise awareness and police themselves. It's already turned into a political process for certain teams lobbying for these collusive and opponent score padding strategies. If the majority is against the practice, then TURN THE POLITICAL PRESSURE AROUND. Distribute flyers within the pits on Thursday that both inform teams about the new ranking/seeding system (apparently a MUCH NEEDED practice) and state the larger, ideal-impacting arguments against scoring for the opposition, strategic advantage be darned.
Ask teams to unite against such practices, and don't let savvier teams manipulate less aware teams into engaging in these strategies. Kill off the "buzz" for scoring for an opponent at an event before it even gets off the ground.
Remember, just because something is permissible doesn't mean it should always be done. You do NOT have to "game the system", as someone put it. A few still will, but they are probably the teams who would seed high anyway even if they didn't resort to scoring for the opponents - they just elect to leverage every advantage they can because the rules permitted them to do so.
Unread 07-03-2010, 19:03
Chris is me's Avatar
AKA: Pinecone
I would take an ambiguous rule over the ranking system we have now any day of the week.
Unread 07-03-2010, 20:26
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Travis, I take it you are against the collusion strategy. If the rule stands, where do you draw the line? As soon as a team begins to lose, i.e. teammate breaks, the other team has 3 balls in during autonomous and your team has 1 kicker etc. Are you asking those teams to believe in miracles and keep scoring hoping they will come out on top, but knowing all they're doing is multiplying the winning teams score? For the sake of honoring a win/loss gaming philosophy? I would feel silly telling my driver to keep on pumping up the other teams score for them and I won't, it's ridiculous! If you're going to get everyone riled up at the regional to take a stand against collusion, you really need to make it clear what are the "NEW" rules. I would rather leave that to FIRST.
However, I like your idea of no opponent scoring! But I think FIRST needs to act fast on this or at least make a public acknowledgment of this situation.
www.179swampthing.org
Unread 07-03-2010, 20:34
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This thread is pointless because hundreds of teams have already competed and FIRST will never make major changes to scoring rules after the season is underway.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-03-2010, 21:03
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
In 2007 FIRST implemented a broken randomizer for Qualification matches. Teams in the first few weeks of competition ended up playing the same teams 5+ times, sometimes being beat each time. They recognized the problem and attempted to fix it around week 3 or 4. Was it a good fix? Not really, but it was better than the original algorithm.
FIRST needs to learn from past mistakes, and just get rid of the broken ranking system now. Sincerely apologize to the teams that only competed in week 1 for the horrible ranking system and go back to Win-Loss ranking. If I were still competing I would much rather they fix the problem now, recreate the intent of the “Coopertition Award”, and have gotten the bad end of the deal in week 1. Especially when compared to having to listen to people complain about how "un-GP" a legitimate strategy is that only exists because of a broken system.
FIRST made a mistake, teams exploited it to the advantage of ALL teams involved. If they are going to keep the ranking system then don't take away the LEGITIMATE strategy of 6v0. But if FIRST wanted to take the game out of the game, they did an amazing job of it.
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 07-03-2010, 21:13
O-H
In such an outmanned situation, I'd feel sillier and believe I'd be harpooning the spirit of the term competition if I were to pump balls into the other team's goal.
If I were in an outgunned situation, I'd switch to defense. I agree - it's silly to elevate the other alliance's rank (as well as your alliance's seeding score with this year's loophole/oversight/intentional decision/whatever the heck it is) just for the sake of nothing better to do. Spectators/sponsors/etc. won't understand what they are seeing, and you aren't furthering any FIRST ideals by providing those "fake points". The opposition didn't earn those scores. You didn't earn those scores shooting into an undefended goal. At least if I played defense, I'd still know that any scores they managed to achieve were earned against LEGITIMATE OPPOSITION, not via some misguided vision of forced "cooperation".
As would I. Absent any action from FIRST, however...teams may choose to employ other means of getting the message across....
By the way, did other regionals neglect to play the game animation? I don't recall seeing or hearing it. I missed DC regional Saturday ceremonies, and I don't believe it was played at Friday opening ceremonies at all. Maybe they showed it throughout the day - I was in the pits almost exclusively.
Sure would be nice.
Unread 07-03-2010, 22:12
The Lucas's Avatar
CaMOElot, it is a silly place
It is easier to just to change Section 9.3.4 and give the losing alliance their penalized score instead of the winners unpenalized score. That would eliminate the 6v0 scenarios there would be less reasons to score in opponents goals.
To implement this change, all you would have to modify is a calculation in the scoring system. To not count balls scored in opponents goals, refs would have to enforce an ambiguous rule (often doesnt turn out well, and puts undue stress on the refs) and mess with the best real time scoring system we have ever had. The automated RTS seems to be working better than ever from what I saw in webcasts (certainly better than the ball counters in '06 or the lap counters in '08).
Robot Inspector
Team Goals for the New Season Akash Rastogi General Forum 2 17-11-2008 15:06
Who Has Scored on The Other Side of the rack in Autonomous Mode E. Wood General Forum 5 20-05-2007 23:11
Count the Rivets! Wayne Doenges Championship Event 23 17-04-2007 18:35
The Count down Jeremy General Forum 1 02-09-2004 17:58
Anyone dislike the way the comp this year is scored? Greg Perkins Regional Competitions 11 08-04-2002 19:30
