Go to Post For fun, someone ought to spread out a bunch of petri dishes or something all over a regional and see what you bring home with you. Or not. - KathieK [more]
  #61   Spotlight this post!
Unread 20-02-2010, 19:21
harpal1991 harpal1991 is offline
FRC #1601
harpal1991 is an unknown quantity at this point
Re: 2010 5th Gear FRC Match Simulator
i am having a problem with installation. when i downloaded it i installed phyx on my pc and separately installed the .net 3.5 and the xna and till when i run the setup.exe i get the application install security warning; and when i press install its gives me a message saying "application cannot be started. please contact the application vendor" here is the detail file
PLATFORM VERSION INFO
	Windows 			: 6.0.6002.131072 (Win32NT)
	Common Language Runtime 	: 2.0.50727.4200
	System.Deployment.dll 		: 2.0.50727.4016 (NetFxQFE.050727-4000)
	mscorwks.dll 			: 2.0.50727.4200 (NetFxQFE.050727-4200)
	dfdll.dll 			: 2.0.50727.4016 (NetFxQFE.050727-4000)
	dfshim.dll 			: 2.0.50727.4016 (NetFxQFE.050727-4000)
SOURCES
	Deployment url			: file:///C:/Users/habby/Documents/Downloads/Compressed/5thGear2010v2_1/5thGear.application
	Application url			: file:///C:/Users/habby/Documents/Downloads/Compressed/5thGear2010v2_1/Application%20Files/5thGear_2_1_0_212/5thGear.exe.manifest
IDENTITIES
	Deployment Identity		: 5thGear.application, Version=2.1.0.212, Culture=neutral, PublicKeyToken=0000000000000000, processorArchitecture=x86
	Application Identity		: 5thGear.exe, Version=2.1.0.212, Culture=neutral, PublicKeyToken=0000000000000000, processorArchitecture=x86, type=win32
APPLICATION SUMMARY
	* Installable application.
ERROR SUMMARY
	Below is a summary of the errors, details of these errors are listed later in the log.
	* Activation of C:\Users\habby\Documents\Downloads\Compressed\5thGear2010v2_1\5thGear.application resulted in exception. Following failure messages were detected:
		+ Store metadata "DeploymentSourceUri" is not valid.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
	No transaction error was detected.
WARNINGS
	* The manifest for this application does not have a signature. Signature validation will be ignored.
OPERATION PROGRESS STATUS
	* [2/20/2010 5:57:14 PM] : Activation of C:\Users\habby\Documents\Downloads\Compressed\5thGear2010v2_1\5thGear.application has started.
	* [2/20/2010 5:57:14 PM] : Processing of deployment manifest has successfully completed.
	* [2/20/2010 5:57:14 PM] : Installation of the application has started.
	* [2/20/2010 5:57:14 PM] : Processing of application manifest has successfully completed.
	* [2/20/2010 5:58:27 PM] : Request of trust and detection of platform is complete.
	* [2/20/2010 5:58:29 PM] : Downloading of subscription dependencies is complete.
	* [2/20/2010 5:58:29 PM] : Commit of the downloaded application has started.
ERROR DETAILS
	Following errors were detected during this operation.
	* [2/20/2010 5:58:30 PM] System.Deployment.Application.DeploymentException (SubscriptionState)
		- Store metadata "DeploymentSourceUri" is not valid.
		- Source: System.Deployment
		- Stack trace:
			at System.Deployment.Application.ComponentStore.GetPropertyString(DefinitionAppId appId, String propName)
			at System.Deployment.Application.ComponentStore.GetPropertyUri(DefinitionAppId appId, String propName)
			at System.Deployment.Application.ComponentStore.GetSubscriptionStateInternal(DefinitionIdentity subId)
			at System.Deployment.Application.SubscriptionStore.GetSubscriptionStateInternal(SubscriptionState subState)
			at System.Deployment.Application.ComponentStore.CollectCrossGroupApplications(Uri codebaseUri, DefinitionIdentity deploymentIdentity, Boolean& identityGroupFound, Boolean& locationGroupFound, String& identityGroupProductName)
			at System.Deployment.Application.SubscriptionStore.CommitApplication(SubscriptionState& subState, CommitApplicationParams commitParams)
			at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
			at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
			at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
	No transaction information is available.
  #62   Spotlight this post!
Unread 20-02-2010, 20:06
Chris is me's Avatar
AKA: Pinecone
This may be too much to ask, but could I suggest a controls revamp?
For all but one driving mode, both joysticks are in use, so using the face buttons for ball manipulation is a bit difficult. Could the shoulder buttons be used for that? LB return, RB grab, RT fire?
Also, arcade drive with one thumbstick is a little difficult. In most FRC applications, arcade turning is assigned to the other stick anyway. Could that be done in 5th gear?
  #63   Spotlight this post!
Unread 24-02-2010, 07:41
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Folks - We have updated the 2.1 5th Gear release - See here 5G Version 2.1.1 Announcement
Subscribing to the FIRST 5th Gear Forum (and to this thread) would be a good idea if you want to keep up with new releases.
Blake
  #64   Spotlight this post!
Unread 24-02-2010, 07:45
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
harpal - I'm not sure if we intentionally did anything that would fix the problem you reported; but we would appreciate it if you would download and try the latest release (2.1.1) to see if the problem you reported got fixed as a side effect of the other fixes.
Let us know in the FIRST 5th Gear forum or here how it turns out.
Thanks
Blake
  #65   Spotlight this post!
Unread 24-02-2010, 19:23
FRC #1601
hey thanks for the reply and i have tried downloading the new version of the app but still the same problem presists. if you guys could do me a favor caop all the files in the instrall folder and send video a uploading service just to see if i have all the files
  #66   Spotlight this post!
Unread 02-03-2010, 20:54
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
ATI Vid Card
is it possible to play this with an ATI card? Seeing as how you need the Nvidia Physx engine and all..
  #67   Spotlight this post!
Unread 03-03-2010, 10:13
lachoneus8's Avatar
lachoneus8 lachoneus8 is offline
AKA: Dave
no team (5th Gear - First Robotics Simulation)
lachoneus8 is an unknown quantity at this point
Re: ATI Vid Card
Yes. PhysX uses NVidia hardware if it is available, but if not it will process the physics using software emulation (slower, but should run just fine).
5th Gear: Multiplayer 3d simulation of Overdrive
Here it is in action:
http://www.chiefdelphi.com/media/photos/30906
http://www.chiefdelphi.com/media/photos/33219
http://www.youtube.com/lachoneus21
Mentor for the Marsteller MS robotics club
  #68   Spotlight this post!
Unread 05-03-2010, 21:32
playbass06 playbass06 is offline
"bass" as in the guitar, not a fish
AKA: Chris Schaaf
FRC #1986 (Team Titanium)
Team Role: Animator
playbass06 is an unknown quantity at this point
Send a message via AIM to playbass06 Send a message via Yahoo to playbass06
By the way, guys, thanks a bunch for the quick update you gave us at KC. It solved the problems. We started a few rounds of our 5th Gear tournament today, and it's going fairly well.
And Intel integrated graphics seem to handle PhysX just fine - as does Intel GMA HD cards! (I find it odd how I had a GeForce 7150M that hated PhysX, yet non-nVidia cards work beautifully...)
I think one of you said you had also run into problems with XNA 3.1, but on my laptop it doesn't seem to create any problems.
And I think I heard you were going to be at Minnesota?
  #69   Spotlight this post!
Unread 06-03-2010, 00:10
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Sounds like we gave away too many fixes in one shot - What will we do for an encore? - We need to learn to pace ourselves
We are delighted it worked well - Kudos to David Dobbs for getting us over the hump on that one.
Friday afternoon a couple of players in DC helped us pin down the source of the problem (or at least got us much closer to a diagnosis than we were before) - For a reward we gave them both a 5th Gear polo shirt - There are only 60 in all the world - They are sure to become a valuable collectible (I had better not see them show up on eBay... ).
Yes - Employees/volunteers form Lockheed Martin's Eagan plant are planning to run a 5th Gear exhibit are the Minnesota Regional(s).
Blake
  #70   Spotlight this post!
Unread 07-03-2010, 13:44
AKA: Pinecone
Any word on whether or not this will be at WPI? I just found out I'm going and would like to know how much of my free time will be spent away from my team
  #71   Spotlight this post!
Unread 07-03-2010, 17:49
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
I am unaware if the WPI Regional will include a 5th Gear set-up.
However... If 7 teams each brought one computer/monitor (already proved to run the simulator) and one Xbox Controller, and someone tossed in a LAN switch, seven Ethernet cables, and some power strips - Then, after scrounging up a couple of tables and a power outlet at the event, the answer would be a definite "Yes".
If some of you decide to do this (take the stone soup approach to putting together a set-up), then let me know so that I can send one of you a slightly different copy of the executable and a batch file to automatically restart it after each match.
Blake
PS: Double check with your hosts at WPI before doing this - Not all floor space that appears available actually is available, and not all power circuits will have extra Amps for surprise loads. One phone call or email exchange ought to be enough to pave the way.
  #72   Spotlight this post!
Unread 31-03-2010, 08:44
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Folks - FYI - A programming challenge that can involve 5th Gear
Challenge Thread: Full Thread
Original Challenge: Original Post
My Reply: 5th Gear Post
Blake
  #73   Spotlight this post!
Unread 31-03-2010, 08:52
AKA: Pinecone
Is there an API or something for 5th gear robots? I would love to try some psuedo programming / AI algorithms for Overdrive in my spare time (I used big words to make me sound smart)... is this possible?
  #74   Spotlight this post!
Unread 31-03-2010, 09:06
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
There is an informal description of the interface between the Server and the client that needs to be polished and made more detailed before publication, and there is my Java client-side Client-Server communication code that could be updated and compiled into a set of class files that could be distributed (so that other Java code could incorporate them).
I figure I'm about 40 labor-hours away from being able to release those two items. I also have to get my taxes filed and prep for the 5th Gear exhibit at the Championships, and keep an eye on the Week 5 exhibits, and participate in a May Vex off-season event locally, and design/build some Vex bots that will be used in community College workshops this summer, and take some Vex bots to our local 4H office to show to a Virginia House of Delegates member, and ...
No - I'm not looking for pity but I am explaining why I/we haven't released these two items quite yet.
However, when I saw the other thread I couldn't resist letting folks know that it is possible to release them in the near future, and that those 40 hours might rise up nearer the top of my to-do list if there is enough interest (the tax man and the Championship exhibit have to stay at the top of the list).
Blake
  #75   Spotlight this post!
Unread 19-04-2010, 14:58
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
I just have one question. What are the controls for tank drive and is it possible to change the point of view so that you watch your robot from the alliance station? Also, is it possible to change the buttons for what they do by changing the code? Well, I guess that's actually 2 questions.
2009 5th Gear FRC Match Simulator gblake Technical Discussion 36 10-01-2010 21:16
5th Gear Lunacy simulator at the FIRST Championship lachoneus8 General Forum 3 24-04-2009 19:46
pic: 5th Gear Lunacy Match Simulator at the championship lachoneus8 Extra Discussion 3 12-04-2009 07:58
5th gear Simulator help vbman11 General Forum 6 09-02-2009 09:21
Lockheed Martin/5th Gear Game Simulator... ttldomination General Forum 1 27-01-2009 21:44
