Go to Post I've always thought that what makes an average person exceptional is not their inability to make mistakes, but rather their ability to recognise, rectify, and learn from them. - artdutra04 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #46   Spotlight this post!
Unread 07-03-2010, 13:31
Al Skierkiewicz Al Skierkiewicz is online now
Re: 2010 PEACHTREE REGIONAL
Ray,
The voltage monitor should be coming from the stream of data passing from the robot. To use something from the Classmate seems counter productive to trouble shooting. Since the voltage monitor is the jumper on the Crio analog module, it is passed as data from the Crio to the wireless bridge. It is not essential to Crio operation but does give the field monitors some additional life blood data to help trouble shoot problems. Unfortunately, there are a variety of issues that can cause this loss in the data stream. Only one of which is a total power supply failure.
  #47   Spotlight this post!
Unread 07-03-2010, 14:52
rspurlin's Avatar
rspurlin rspurlin is offline
AKA: Ray Spurlin
no team (no team)
rspurlin has a spectacular aura aboutrspurlin has a spectacular aura about
Al, I have no doubt that you are right. What I'm saying is that the classmate, upon losing the link to the robot, continues to report the last known battery voltage to the FMS log. In my opinion, it should instead report something like 'Unknown', since it clearly doesn't have that data. Thus when we say that based on the FMS logs, the battery retained its voltage throughout the match, we're being at best misleading. With FMS lite we should be able to test that.
The FMS logs in the match at question did show the robot link being lost to the robots in question during autonomous, but not simultaneously. There are many reasons the robot link might fail. We've seen ethernet cables come unplugged and cRios get jostled enough to make a bad power connection drop out and force a reboot as two examples. One is possibly recoverable during the match, the other not. I'm wondering if there was enough startup current draw to pop the main breaker on a robot that was going for its fourth match in about 30 minutes.
And by the way, I am learning something new today - from you and the others in this thread.
Mentor(2007-2013) - Team 1379 - Gear Devils - Norcross, GA
2010 Palmetto regional Semifinalists, Judges Award
2010 Peachtree Regional Quarterfinalists, GM Industrial Design Award
2009 Palmetto Regional Finalists
2008 Bayou Regional Quarterfinalists
2008 Peachtree Regional Semifinalists
2007 Peachtree Regional Quarterfinalists
Georgia FRC Planning Committee
  #48   Spotlight this post!
Unread 07-03-2010, 15:07
Ray,
To be sure the log showed a drop of communication but continued to show a voltage? That is certainly misleading.
  #49   Spotlight this post!
Unread 07-03-2010, 16:31
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Al,
RE: chargers
People tend to choose a faster charger when they really need more smaller chargers. It is my understanding that the batteries for FRC like to be charged at their sweet spot of about 2 amps. So we bought more batteries. I think the economics support that in terms of battery life, performance, and cost per charger channel. Or at least that is my theory.
It is the Deltran 10 bay 2 amp charger. Available from dealers everywhere. We got ours here. Deltran PN 021-0134.
RE: telemetry
In my business the issue of what a downstream telemetry link does with bad data is a common discussion. But in this application it seems like it is clearly a 'range telemetry' type of problem. Therefore the classmate should report what is happening at this timecode and not what happened a while ago. I'm clearly speculating but I'm guessing that the FMS system is polling for data without the benefit of timecode info from the classmate ??????? I'm guessing but inquiring minds want to know.
RE: inspection
I will look into the Raleigh thing. I cannot do Atlanta as I will be getting hammered with other obligations.
Ed
Ed Barker
  #50   Spotlight this post!
Unread 07-03-2010, 16:40
Jeremy Roberts's Avatar
Jeremy Roberts Jeremy Roberts is offline
Coach 4026
FRC #4026 (Global Dynamics)
Jeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant future
Send a message via AIM to Jeremy Roberts
Thanks to all that helped make Peachtree a success. We had our issues but finished with some nail biting elimination matches. It was unfortunate to end the last match without having all robots functional but such is life.
Team 1848 (SOUP) would like to thank 34 for their great offense up front and 3139 for their great defense. With us in the middle feeding balls forward we were a great team. Thanks to 1311 for filling in at the last minute.
The #1 alliance had some great robots and are deserving of their win. Unfortunately we won't be seeing you for FRC at the Championships but hopefully next year.
Jeremy Roberts
GeorgiaFIRST Planning Committee | Peachtree Regional
Georgia Tech RoboJackets FIRST Co-Founder
Engineer/Mentor 4026
Former teams: 132, 608, 832, 1002, 1848
  #51   Spotlight this post!
Unread 07-03-2010, 17:35
MikeReilly's Avatar
MikeReilly MikeReilly is offline
FRC #4509 (Mechanical Bulls)
MikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud of
Hopefully we can now move on to other cool things at Peachtree. What else was cool?
How about when 590 hung for the first time?
How about when Oscar threw up his battery? (Sorry, but it went immediately to long term memory for me.)
How about when 1261 shot completely down the field in autonomous? (Sorry, once again, ingrained.)
I truly believe Coopertition was epitomized with our Elims trio. I loved the timed autonomous shots of 1771, then 1683, then 1466 pushing them home. Granted, I think the most we saw was 2, maybe 3, but the point was the teamwork. Okay, maybe it was cooperation, not coopertition (they really need to get an emoticon for a Copyright for that "coopertition" thing here), but it was excellent communication and solution.
Great tournament GAFIRST!!
Mentor for Rookie Team 4509, Formerly with 1771
  #52   Spotlight this post!
Unread 07-03-2010, 17:40
Coach 4026
Just a reminder: If you're going through Peachtree withdrawl NASA has many matches online at http://www.ustream.tv/channel/frc-peachtree-regional/v3.
Jeremy Roberts
  #53   Spotlight this post!
Unread 07-03-2010, 17:41
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Oh I'm so going down in history for that this year... That's what I get for moving the speed from 20% to 100% when also changing when it turns on. Doi! Our alliance partners weren't too happy afterwards though, but at least you have to say it was the most surprising autonomous done.
Seeing robots climb is still awesome to me.
I don't remember who the team was who pushed three balls in at the final match, but I quite liked that moment (spite whatever call was made for the scoring). 'Twas very lucky and exciting to watch.
*goes to see if I can find that autonomous on ustream*
-Tanner
  #54   Spotlight this post!
Unread 07-03-2010, 17:49
ttldomination's Avatar
Sunny
God...that was..."scary" to say the least. Our autonomous composed of charging the kicker, and I was getting bored of that, so I convinced our programmer to code something basic, even if that meant going forward. Unfortunately it went backwards. I remember thinking "CRAP IT'S GOING OVER A BUMP...it's ok...it'll stop...CRAP IT'S GOING OVER THE SECOND BUMP."
We also managed to damage 2566(One of our alliance partners for that round) and I do apologize for that.
The one time that 590 got itself up, it looked to me like they were all over the ball track, which I thought was an immediate DQ...
1648: 2013-2014
5283: 2015
  #55   Spotlight this post!
Unread 07-03-2010, 17:53
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Originally Posted by Tanner View Post
........ I don't remember who the team was who pushed three balls in at the final match, but I quite liked that moment (spite whatever call was made for the scoring). 'Twas very lucky and exciting to watch.
-Tanner
It was team 34 during the first match of the Finals. 34 was pushing 2 balls but a third ball kicked by SOUP rolled up our top plate and dropped in a split second before we got to the goal. You can find the video on the "Blue alliance" website. I've watched it 10 times in disbelief.
Ed Sparks
MECH TECH FRC-3959
  #56   Spotlight this post!
Unread 07-03-2010, 17:55
Tanner's Avatar
There are matches on TBA? I don't see any matches with video on my end.
-Tanner
  #57   Spotlight this post!
Unread 07-03-2010, 17:56
elemental elemental is offline
DAAP Slapped
AKA: Erin
elemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of light
Just as our robot was working again...
Ah well. Our media guy got a nice video of it.
  #58   Spotlight this post!
Unread 07-03-2010, 17:57
Sunny
Can you please link the blue alliance page? From what I see, they don't have any videos of P'tree from this year.
1648: 2013-2014
5283: 2015
  #59   Spotlight this post!
Unread 07-03-2010, 18:03
http://www.ustream.tv/recorded/5239242
It starts near 00:06:30.
Ed Sparks
MECH TECH FRC-3959
  #60   Spotlight this post!
Unread 07-03-2010, 18:15
Coach 4026
Wow, I just watched that again. I didn't realize that we kicked that one over you and in.
Jeremy Roberts
2010 Peachtree Regional ttldomination Regional Competitions 15 11-12-2009 07:19
2009 Peachtree Regional ttldomination Regional Competitions 139 09-04-2009 22:50
FF Peachtree Regional Collmandoman Fantasy FIRST 64 08-03-2005 17:04
Peachtree (GA) Regional Thread KevinB Regional Competitions 9 21-03-2004 12:16
Peachtree Regional Stephen Kowski Regional Competitions 2 18-03-2004 06:49
