Go to Post Maybe Dean Kamen can appear in Levi's advertising? - David Brinza [more]
Unread 07-03-2010, 17:44
Roborocker87 Roborocker87 is offline
Roborocker87 is an unknown quantity at this point
Breakaway Elimination Strategy
Assuming the following:
Ignore the Qualification Matches, these strategies are only for Elimination, where winning means something.
Assume you can pick any alliance within reason. (i.e. a middle-long range bot+ a defender + a herding bot would be a possible team makeup.)
What were the most effective strategies that you have seen played out?
Unread 07-03-2010, 17:48
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Breakaway Strategy
You should probably change the title of the thread too Breakaway Elimination Strategy so it doesn't look like you are going over other strategy threads that have already made.
Unread 07-03-2010, 17:52
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
In our elimination matches, we went with a standard one robot in each zone setup for almost all cases. The alliance of 217, 1551 and 174 who won the championship, would start out one in each zone, then after 217 shot their balls in autonomous, 174 and 217 would switch places, allowing 217 to continue racking up points. The main strategy to emerge as successful was one strong midfielder with good abilities deflecting balls, an efficient scorer, and a defensive robot to assist the midfielder and slow down the opposition. It also helped to have a hanging robot in the alliance to save a close game at the end.
To defeat 217, 1551, and 174, we switched our formation to one offense and two midfielders, allowing us to box out 1551 and deny 217 balls long enough for us to even the score.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 07-03-2010, 17:59
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Breakaway Elimination Strategy
An interesting fact, 174 could only push balls, and it was REALLY GOOD AT IT!
I can't personally comment on strategy during elimination, due to the fact that when our alliance played, two of our alliances robots were offline.
What seemed to work well for other teams was to have your fastest robot in the defending zone, because if they could out-maneuver the offending robot, then it was almost impossible to score.
Another thing, hanging was highly situational, based on the amount of balls in the offensive zone.
Unread 07-03-2010, 18:04
Scoring more points than the other team.
Unread 07-03-2010, 18:06
AKA: Simon Bohn
I disagree. Playing good defense was just as, or more important.
Unread 07-03-2010, 18:11
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
E-M-P . . .
However, in all seriousness I agree that it would serve wise to have a very strong defense in the far zone. A highly maneuverable robot would possess the qualities necessary to deny the opposing alliance any soccer balls to score.
In BAE 1073 and their alliance reigned victorious over 78 and their alliance members through the aid of this tactic. 78 was in their own near zone and attempting to score. However, whenever their vacuum would gain possession of a soccer ball, the defending robot would tap/ram (perspective) them so they lost hold of the game piece. Hence, denying them from successfully scoring much needed points.
Unread 07-03-2010, 18:23
ttldomination's Avatar
Sunny
So let me get this straight...in the elimination rounds you do not agree with scoring more points than the other alliance? Well, I'll be dammed...that's one heck of a strategy.
In finals, we *tried* to do what everyone else did, that is one defender in far zone, one ball relayer in the middle and a consistent scorer in the near zone, but all three positions were very poorly executed and therefore we took hard losses.
1648: 2013-2014
5283: 2015
Unread 07-03-2010, 18:31
President, VEX Robotics, Inc.
I can tell you the best strategy is to not have one strategy. The only loss we took was due to us not changing our strategy when dictated by the other alliance's play. The 1511/3157 alliance changed their strategy and we did not adjust. We learned this lesson and had a few "option" strategies based on how they defended us.
The elimination round version of this game is very exciting.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 07-03-2010, 19:01
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
It would be nice if the whole game was like the elims.
Who know? Maybe people would actually enjoy watching qualification matches! (WHAT A REVELATION!!!!)
Ah well, there's always the off season.
Unread 07-03-2010, 19:07
AKA: Simon Bohn
I see quite alot of people here from FLR...
See ya at Ruckus!
Unread 07-03-2010, 19:08
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Originally Posted by Vector MycroftH View Post
E-M-P . . .
Haha, many times it was a lighter ram due to our driver trying to get away from 134 (they are REALLY good at defense), but most of the time all three robots (two red one blue) were together as a group making it impossible for balls to be shot. We have a picture that they sent to us with them pushing our robot and we have two wheels on the ground. With two strong drive trains going at it, you will have airborne robots.
Our strategy was very plain. One bot in each zone, one defense two offense.
1058 PVC Pirates 2016 - xxxx
Unread 07-03-2010, 19:14
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
See ya at Ruckus!
Please do come.
It's 24 (or more) or bust this year!
Unread 07-03-2010, 20:08
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
In reference to alliance structure for the eliminations a good structure seems to be this:
Striker: The Robot that plays in your scoring zone. They should be fast, agile, be able to take defense, and be well driven. They DO NOT have to have a kicker. They just need to be very efficient at getting the balls on the floor of the scoring zone into the goal.
Mid-Fielder: This Robot plays in the middle of the field. Once the match starts, all balls flow out from the mid-field (ball return), and I found that if you can control the midfield you can control the match. This robot should be reasonably fast, have a strong drive base, good ball control, and a decent kicker. It's a bonus if this bot can hang because it's already close to the tower. This robot's kicking and ball handling mechanism should be the best on the alliance IMO, because in some cases scoring from the midfield is very important if your bot in the scoring zone is d-ed up. This robot should also have an autonomous that can get balls out of this zone. Your Mid-Fielder also needs to be able to get out of this zone to score in the scoring zone if need be.
Defensive Bot/Goalie: This robot plays in the opponents home zone. This bot should have a strong drivebase, a powerful kicker (Kicking across both bumps is best) and good ball handling. This machine is responsible for clearing the scoring zone of your opponent and bringing the balls down to their scoring zone. The kicker here doesn't NEED to be super accurate although it is Preferred. This robot also needs an autonomous mode capable of clearing some or all of the balls out of the opponents zone.
This is also based entirely around playing the game in a certain manner. You get as many balls as possible down into your scoring zone using the mid-fielder and "goalie" and then the striker is responsible for cleaning up any missed shots. In some matches this won't work well because of other factors but it's a good base strategy. In many cases the Goalie will need to move up an assist the mid-fielder to keep strong control there.
But this is just my two cents so feel free to disagree.
-Dustin Benedict
Unread 07-03-2010, 20:13
AKA: Simon Bohn
Please do come.
We will defiantly be attending this year, as we have for the last few. Wasn't it 25 in '09?
It's a little off-topic, but how do the X-Cats manage to attend so many events?
You guys are going to like, 5 regionals!
pic: 2240 Breakaway viperred396 Extra Discussion 14 27-02-2010 20:34
2077 BREAKAWAY robot! tutkows1 Robot Showcase 7 25-02-2010 23:01
Breakaway Discussion Joe Schornak General Forum 131 20-01-2010 17:53
Breakaway Logo WilliPri General Forum 2 09-01-2010 13:00
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
