Go to Post My father taught me long ago that how we respond to adversity is what defines us as human beings. Let's all keep this definition in mind as we move forward to change a culture. - Rich Kressly [more]
Unread 07-03-2010, 17:35
Ed Sparks Ed Sparks is online now
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Hints and Observations from Breakaway - Week 1
Here are some random thoughts about what I observed at Peachtree during week 1 of "Breakaway".
1. Balls that rest in the intersection of the bumps and the outside perimeter of the playing field are G46 "Land Mines". Be very carefull when trying to retrieve these balls. Comming over the top of a bump to recover these balls just about guarantees a G46.
2. Fast mecanum "plows" are very effective in the scoring zone but are starved of balls rather quickley. It takes kickers to keep a supply of balls comming.
3. The Q&A indicates that it is ok to plow multiple balls as long as they are not possessing more than one. This was mis-understood at Peachtree.
4. There were far too many teams at Peachtree with the wrong cRIO and DS image. This caused great loss of practice time and some missed matches. You absolutely must have the latest versions or you will not connect to the FMS. Bring it with you if your not sure!
5. Bungee cords and surgical tubing are not effective in keeping balls from violating G46. You really need some sort of hardware that floats vertically and rests below the center of the ball when your not on the bump.
6. I stick with my opinion that a good plow-bot can score more points with balls then with hanging in the finale (If you can get the balls in the score zone before the finale).
7. The inspection process was longer this year. Don't wait until the last hour to get this done. At Peachtree, we only managed to pass about 55% of the teams at pit closing on Thursday night. The big ticket items were software versions, pneumatics, and bill-of-materials. The BOM process is different this year, take time now to get it right and be prepared. The inspection process requires that you submit your BOM electronicaly to the inspector's table where a copy is placed on a PC. There's a required format that's available from FIRST in the game documents page. One more thing, your suppost to break your BOM into components (including the kit parts). Don't bring a BOM that has something like "Quantity 1 - Frame ..... $100".
8. Charge your classmate every chance you get. There is a definate problem for teams that make it to the final 8 concerning this. At Peachtree, half of the classmates were just about to die when the last match was played (due to all of the delays and tie matches). Get a plan now, make someone responsible to manage this.
9. I observed the wierd main breaker issue again this year and it even bit our team in the finals. Make your field team aware of the possibility that the main breaker could open on it's own without actually tripping. If your robot "dies" for some unexplained reason during the match, have your team first notice if there's any power on the power distribution panel. If not, have them check the 120A main breaker to see if it's tripped. If it's not, then you too were bit by this and it's not the fault of the FMS. I'd like for all of us to watch for this and I'd like to know about it if you see it.
10. Bumper construction was better that I expected this year. The only significant issues I had were those who used bumper covers. Your still expected to be able to remove the bumpers for the inspection process. Some didn't expect to remove their bumpers and it was painful for them. The covers were also a bit of a problem beacuse they were often a loose fit and sagged down below the 10" lower bumper limit. If your in this camp, figure out a way to take up the slack.
11. I'll bet 75% of the teams this year used pneumatics (many for the first time). Be sure your using the FIRST supplied primary regulator(60psi). many teams don't realize that the last module on the cRIO can directly drive the solenoid valves. Many still think your required to use spikes. You can do either but using spikes adds weight and is unnecessary.
12. Too many robots came out of the box with kickers that could break the bumper perimeter plane. Inspection and referees are looking for this.
Hope this helps your team and good luck.
Ed Sparks
MECH TECH FRC-3959
Unread 07-03-2010, 17:40
Wildcat's Avatar
Wildcat Wildcat is offline
AKA: Jeff
Team Role: Scout
Wildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the rough
Re: Hints and Observations from Breakaway - Week 1
13. just cause you have an "anti-flip mechanism/design" doesn't mean it works
Network switch: $25
Gas, drinks, and pizza for a road trip to Troy:$50
Mountain Dew, Nachos, and Pizza at States:$200
Being a member of the Scouting Team: Priceless
2010 & 2011 Scouting Coordinator
2010 Back-up Driver (2-5)
Unread 07-03-2010, 17:41
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Thanks for your insights, Ed. Especially for those related to inspection. I hope in future regionals, teams come with their firmware properly updated and an electronic BOM ready to submit.
Congrats on the WFA!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 07-03-2010, 18:07
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
14. Make sure you've also had your encryption key set on the robot radio before getting to the field.
7. The inspection process was longer this year. Don't wait until the last hour to get this done. At Peachtree, we only managed to pass about 55% of the teams at pit closing on Thursday night. The big ticket items were software versions, pneumatics, and bill-of-materials. The BOM process is different this year, take time now to get it right and be prepared. The inspection process requires that you submit your BOM electronically to the inspector's table where a copy is placed on a PC. There's a required format that's available from FIRST in the game documents page. One more thing, you're supposed to break your BOM into components (including the kit parts). Don't bring a BOM that has something like "Quantity 1 - Frame ..... $100".
Amen. I was an inspector on Thursday at Kansas City. I believe we had about 6-8 robots that didn't pass inspection until Friday, and at least half of them were waiting on the BOM. That was the single most common difficulty all day (apart from the usual "sharp edge, please file" and robot diet issues).
Unread 07-03-2010, 18:23
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Ed,
Thanks for the insight. Speaking of BOM, are they REQUIRING the weight or is that just there for your convenience?
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 07-03-2010, 18:25
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
15. Be careful with your E-stop button - they do break, and there aren't extras at the spare parts table (or at least, there weren't in Traverse City). You probably won't find a team with an extra one, either.
16. Gloves were provided in the KoP for a reason - use them! They count towards the safety award. And as always, lift from your legs and not your back.
17. It's difficult to see a ball from the driver's station if it's right up against the far side of the far bump.
18. Even if you DO have a hard mechanism to keep balls out from the underside of your robot, charging at a ball too fast may still result in your robot going over it if that mechanism isn't below the center of the ball.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 07-03-2010, 18:27
Originally Posted by Kevin Ray View Post
Ed,
We didn't worry about the weight at Peachtree. My opinion is that it's optional but a question to the Q&A is probably in order here. There's nothing in the rules about any one component weighing less than XX lbs so I suspect it's just there for team use.
Ed Sparks
MECH TECH FRC-3959
Unread 07-03-2010, 18:31
vhcook's Avatar
Reader of Things
AKA: Victoria
We didn't require weight on the BOM at KC either.
Unread 07-03-2010, 18:55
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
At the San Diego regional, we were penalized for possessing two balls when we possessed one and were herding another. We challenged the penalty. From what our student said, the Ref that made the call said that that was the way he had been making the call all day. The Head Ref's decision was to let the penalty stand and tell the Ref to call them correctly from then on. We ended up with a 3-3 tie and 3 standing points. Without the call, the win would have been worth 10 standing points. A 7 point penalty - don't you just love the new ranking system.
We had the Classmate on the charger just about every minute that we were in the pits. We were in the red at the end of the quarter finals. GP got us a battery to use for the rest of finals. Unfortunately, I don't know who to thank.
Make sure that it is the primary (black ring) not the secondary (yellow ring) regulator. That slowed our inspection for a few minutes.
Unread 07-03-2010, 19:10
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
We encountered the following issues at San Diego:
1. We were told a printed BOM would be OK, it's not. Be sure you have the electronic version on a memory stick for the inspectors. And it needs to include all the KOP items you used on the robot.
2. We were told our bumpers did not properly close at the corners and could just zip tie pool noodles into the corners. Wrong. We had to extend the bumper fabric to cover the added pool noodles.
Once we got past these issues, the only remaining issue was the pressure relief valve not releasing at 125psi. This issue was brought up in team update 11 but the problem was finding someone that knew how to adjust the relief valve. Basically you run the pressure up to 125psi, loosen the jam nut and back out the top of the relief valve until you hear air starting to escape, then tighten the jam nut back down.
Other than that, things went great. Huge thank you to 599 for their Robot First Aid Station, what a life saver.
Unread 07-03-2010, 19:13
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
19. When playing in the offensive zone, have the human players give you a heads up when your robot scores. They can see the goals far better than you can.
Unread 07-03-2010, 19:25
Sunbun's Avatar
Sunbun Sunbun is offline
AKA: Sunny
FRC #1197 (TorBots)
Sunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of light
Seconded. I was HP for half of San Diego and our driver thought it was really helpful to have the HP scream "BACK! BACK! FORWARD! FORWARD!" when the bot tried to score.
I'll add:
20. If you have the trident, or if you're a human player, careful not to step outside of the white line. That's a penalty.
Also be sure to ask if the "Trident Guy" wants the ball rolled, tossed, or placed onto the trident. Every little bit of time saved counts.
Unread 07-03-2010, 19:34
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Ed,
There was a Q&A response that said it was not required.
Sorry I don't feel like searching right now.
Unread 07-03-2010, 20:47
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
21: (either this is bad luck for us, or something to look for)
our pneumatics leaked. we had to boot up our robot in field-que and charge the tanks around 15 seconds left in the match. every time we did this, our computer messed something up with the joysticks, either they were reversed, or in the wrong places, or we lost I/O...
I think the rapid disconnect from robot, and connect to field system may have had something to do with it.
we stopped doing it, and we stopped having issues...
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 07-03-2010, 21:16
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Something about the way joysticks are handled on the classmate is flakey. We were left dead in the water during two matches because our joysticks didn't work.
At the KC regional, the field tech instructed us to use the following procedure, and we never had the problem again:
  1. Enter the field with the robot turned off and the classmate logged off.
  2. Have the people who set the robot down watch the display above Your Team's DS, and have them signal the person at the DS to plug in and then log on when your team number shows up.
  3. Have the person at the DS signal the people at the robot to turn it on when the classmate displays the "FMS connected" message.
  4. Win your match!
Interesting Observations of Week 1 IKE District Events 5 13-03-2009 11:15
Observations after week ! Creator Mat Rules/Strategy 73 05-03-2009 23:36
Safety Observations from Nationals UCGL_Guy Championship Event 0 01-05-2006 16:05
Revised Rules and Helpful Hints Brandon Martus Announcements 0 25-05-2005 10:44
Observations from West Michigan Regional archiver 2001 3 24-06-2002 02:13
