Go to Post try to be a little less quick to hit the red rep and a little more informative and helpful. - JaneYoung [more]
Unread 07-03-2010, 20:06
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Watchdog
We keep having Watchdog issues. We only have one Watchdog, between Autonomous and Teleop, but it causes us to not be able to run anymore. We have tried everything to fix it and still no luck. We ran the sample code and still we get a watchdog. We have swapped out the cRIO, still no luck. When we are running in the pit or on the practice field it does no affect us but when we go out on the actual field we get the watchdog and than we can't move anymore. Anyone have the same problem and figured out a way to resolve it? We had multiple teams try to help. We also had a National Instruments person try to help and still nothing.
Unread 07-03-2010, 21:12
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Watchdog
I noticed something similar in our code this weekend. It was when I would enable/disable into and out-of autonomous.
My fix was looking into what I was doing within the INIT and STOP cases of the Auton and TeleOp and Disabled VI's. You get one execution of either one, every time you enter/exit those VI's. Make sure you're not doing stuff in there that might take too long.
My problem was accessing resources that weren't present (i.e. when the camera or gyro wasn't connected). When I eliminated those references, my watchdog errors disappeared.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 07-03-2010, 21:18
kgzak's Avatar
AKA: Kris
Re: Watchdog
I'll look into that but I don't think we do anything there. Even the out of the box code doesn't work. We open a new project and don't change anything, still watchdog.
Unread 09-03-2010, 20:59
kgzak's Avatar
AKA: Kris
Re: Watchdog
Is the watchdog suppose to timeout between Auton and Teleop? We keep getting the error in between the two.
Unread 09-03-2010, 22:58
Re: Watchdog
Look at what your code does in Autonomous. If it completes its task before the 15 seconds are up, does it keep feeding the watchdog? The default LabVIEW project doesn't.
Unread 10-03-2010, 10:50
Re: Watchdog
It's okay to throw a user Watchdog in Autonomous if you aren't doing anything. Watchdogs aren't bad in and of themselves.
A Watchdog during Autonomous (after you finished doing anything) doesn't prevent Teleop from starting (as long as Teleop feeds the Watchdog).
It's when you throw one and you were supposed to be doing something, then that's a problem.
Unread 10-03-2010, 15:36
kgzak's Avatar
AKA: Kris
Re: Watchdog
I'll look into it. But we ran an autonomous that all it did was feed the watchdog and still had issues. I may have screwed something up though.
Watchdog Problem daniel_3158 Programming 3 12-02-2010 15:22
Watchdog!?!?!?! NC GEARS General Forum 38 23-01-2010 08:52
WatchDog Timeout popo308 Programming 3 22-02-2009 22:04
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
Watchdog Barchechath Programming 6 10-02-2007 20:05
