Go to Post Our opponents didn't know where our robot was going and neither did we! - ReapersRule [more]
Unread 06-03-2010, 21:24
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Power Management Recommendation for driver stations
At the 2010 Peachtree Regional the teams that played Saturday afternoon essentially had to play the afternoon on whatever charge existed on their Classmate. It was rough on the classmate battery.
When teams are at the driver station the classmate has to be running on its internal battery only !!
I would STRONGLY suggest that you get a dc-ac inverter, 100 watts or so. You can buy them at Walmart or a truck stop for $ 20 or so. Put an Anderson powerpole connector on it and plug it into a robot battery. Put the battery/invertor combo on your robot cart and it can keep the classmate topped off and ready for your match.
Then as you sit in queue Saturday afternoon you will topping off the classmate and be in great shape with the driver station. When you go to place the DS for the match you just pull the plug on the classmate and go to work.
It will cost less than a second classmate battery and you can use it as a power source for driver stations for public demos and to do a hundred other things.
Ed Barker
Unread 06-03-2010, 21:43
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Re: Power Management Recommendation for driver stations
one of the mentors from our team brought a portable laptop charger, and it worked phenomenally!
it was kinda like what you are suggesting, but in a light, conviniently small package. it weighed no more then 3 pounds, and was about the size of a letter envelope, and about a half an inch thick. it powered the laptop for the entire day whenever the laptop was not in the pits, and it still had charge to spare at the end of the day! (it is also re-chargable itself, so its uses are unlimited)
our classmate battery never dropped below green!
it definitely saved our butts in the finals.
I was happy we had it when I walked around and saw red battery indicators on some of the other teams' screens...
If I knew the model number or anything, I would tell you, but I don't.
Maybe Ill ask our mentor at the next meeting, and post it here. the thing was a lifesaver!
EDIT: AND!
we talked to the head ref, and he said that it was legal to keep it plugged in durring a match, so the laptop did not go into power-conserve mode.
It seemed to speed up our camera-image speed a bit.
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 06-03-2010, 21:51
Bharat Nain's Avatar
It helps to turn the wifi off.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 06-03-2010, 21:52
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Yeah, our team was feeling a bit of "red" so to speak on Friday afternoon.
We're currently looking forward to doing something to aid in keeping the Classmate alive for matches. What has been said here is great, specifics would be fantastic.
I still wonder why they didn't have a power cable on the alliance station - just to make things a bit less crazy for set up and stuff? Having a DS with a battery is nice, but some days its nice to have a power source.
-Tanner
Unread 06-03-2010, 21:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Do you have any specifics on this device? Sounds interesting. I am currently designing/building a similar device. Would there be any interest for this?
Unread 06-03-2010, 21:57
Jazonk's Avatar
Jazonk Jazonk is offline
It's all a balancing act.
AKA: Dino
FRC #0027 (Team RUSH)
Team Role: Driver
Jazonk will become famous soon enough
Send a message via MSN to Jazonk
What we did was just close the classmate after every match, bring it back to the pits and let it charge. Any time we were not on the field, it was charging in the pits. For eliminations, we went to the 3rd match of the semis, and we had plenty of battery left. The key is to leave it on the charger, and to close it after every match (it goes to sleep).
If you think education is expensive, try ignorance. -Derek Bok
Unread 06-03-2010, 22:05
Kage's Avatar
AKA: Kage
I do not know anything about it right now.
now that I think about it, the mentor who it belonged to is going away on a week-long buisiness trip tonight, so I will not know anything about the device for a while :|
I will try and let people know what it is as soon as possible!
the most I could tell you about it now is pretty much that it was a rounded-edged black box with about a 5" cable coming off of it. haha
Unread 06-03-2010, 22:10
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Power was a bit of a problem for us as well. The matches drained power faster than we could build it between matches. By the end of Friday the battery was almost dead. At least emergency charging is available during eliminations.
Make sure you leave your classmate charging overnight at competition. It's the only reason we survived Saturday
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 06-03-2010, 22:14
ebarker's Avatar
AKA: Ed Barker
I'm a big fan of invertors / Anderson connector / robot battery arrangements because it give you a pool of batteries that interchanges with the robots and allows you do do all sorts of things.
Kinda like the military 'one fuel' concept. They have jets, helicopters, tanks, humvees, trucks, and motorcycles that run off the same fuel.
Ed Barker
Unread 06-03-2010, 22:56
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I wonder why FIRST couldn't add power cables for the Classmate. I would see it as a very cheap solution. FIRST should get feedback about this because it does seem like a bit of a big problem that you can't compete because the Classmate battery is dead.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 06-03-2010, 23:03
ebarker's Avatar
AKA: Ed Barker
Inertia - The trucks are loaded and rolling from regional to regional. Getting the solutions configured and shipped out and meeting the trucks at the next regional, implemented and rolled out to the next events I'm sure is an effort. And they are most certainly busy setting up for the CMP.
The cost of implementing the power cable solutions means that something else isn't getting done. It is an economic opportunity cost problem.
Having the battery / invertor combo is great for demos. You can solve two problems at once.
Ed Barker
Unread 06-03-2010, 23:08
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
We found that to be a HORRIBLE idea. Every time we would close our Classmate, the joysticks would get out of order, and often times it forced us to reboot the entire system.
Much better to just grab an extension cord and plug it in. (Bring some tape to secure it down better so robots can pass through if needed.)
Unread 07-03-2010, 22:19
Ed,
The venue should be able to dig a few power drops out of their house box in a minute or two. All it requires is a threeway extension cord at each player station.
Unread 07-03-2010, 22:33
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
We also have a small inverter with connectors to a 12 v battery. We are using some of the older ones that we don't want on a comp robot anymore.
We plugged in the laptop to this "charger" any time we were waiting in line.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 07-03-2010, 22:34
ebarker's Avatar
AKA: Ed Barker
Roger that, I copy your comments well !!
However I posed the question to someone in the know at the event and the answer was negative.
Who controls the field facilities ? The GDC ? FIRST engineering ?
The question needs to be asked because without consistent guidance from HQ there is going to be some confusion.
Our cart now has AC power on it so our alliance members can stay plugged in and charging during queueing. And we have a handheld AC kit for the opposing alliance so they can go ditto !!
When the teams move forward they can pull the plug and place their equipment onto the driver stations. All that doesn't interfere with any understanding that FIRST has at this moment.
Should I post this to GDC Q&A ?
Ed Barker
Laptop recommendation for inventor/pro/e/etc Zyrano CAD 6 28-01-2010 23:20
"vertran" teams not getting the new driver stations?!?! BEEKMAN FRC Control System 6 06-11-2009 20:10
Power Driver Station with Serial pyr0b0y Technical Discussion 6 30-04-2009 19:53
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Laptop for FRC Labview: Recommendation Wanted Foster National Instruments LabVIEW and Data Acquisition 2 22-11-2008 21:14
