Go to Post I hate having to wear official pants. - Cothron Theiss [more]
  #31   Spotlight this post!
Unread 07-03-2010, 22:07
pfreivald's Avatar
AKA: Patrick Freivald
Re: Suspending
Originally Posted by Alex Cormier View Post
I was hoping we could have a match with you. I really wanted to be the first to get the 3 points! Come late friday night we had our hanger all worked out and beautiful. We could lift in 10 seconds or less from the floor in all of our three sat matches with ease.
Unfortunately by then we had removed our bar cover because of a near red-card when it bumped the ball return. (Fortunately, the egregious bump was caused by an opposing alliance robot who will remain nameless -- so they were red-carded instead). Dante warned us of the situation, and we fixed it by removing the bar cover.
Otherwise, it looks like some of you are confusing SUSPENSION with ELEVATION. We had quite a bit of ELEVATION at FLR (more than most of the other regionals, looking at the hanging points), but no SUSPENSIONs.
If we only count our lifts on Saturday, I would think that we were the best lifter behind 1551. (or no?)
I think it was a close thing between you guys and 1559 for second place on lifting. Great job, rookies!
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #32   Spotlight this post!
Unread 07-03-2010, 22:12
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Suspending
Patrick
Thanks, we will have a improved and ready robot come Ruckus time. Maybe we will pair up then?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
  #33   Spotlight this post!
Unread 07-03-2010, 22:34
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Suspending
Originally Posted by Ryan_Davis View Post
Eastridge Robotics 3157 is proud to be an FLR suspender, along with Lockport 1507, Victor 1559, and Naples 1551. There were some occaisonal suspensions from Pittsford 3181, 1126 Sparx, and even 191 Wilson-Magnet.
Um... Noone suspended at FLR. You guys did a good job elevating though!
  #34   Spotlight this post!
Unread 07-03-2010, 23:22
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: Suspending
Originally Posted by Clinton Bolinger View Post
To add to what Zach said:
In the match with 1322, one of the two hooks on our Team's attachment mechanism was not secured to the field tower. Team 1322 successfully attached their robot to our supports, but since we were not completely attached to the tower, it caused our robot to move into a lower vertical position where we were no longer considered elevated. We are able to successfully elevate our (single) robot with the support of one hook, as proven in two matches at the Kettering University District.
After the aforementioned match, we discovered the root problem of the difficulty of attaching both hooks, and made some physical modifications to the design. These changes yielded positive results, which allowed our robot to successfully elevate itself in the successive matches.
I would also like to thank Team 1322 for your immense efforts to attempt to suspend your robot from ours. Had our Team's second hook successfully attached to the tower, we certainly would have seen the first elevate/suspension! Thanks for all of the great teamwork!
-Clinton-
Thank's Clinton, We almost hung but with our hook droping almost 2 feet below the bar hieght it took extra time for the cable to wind up on our wench. Once it caught up and started to hang time was up. I am positive if your second hook would have caught we would have done it.
I bet you will get many chances coming up to sucseed. With the low scores it can be a game decider.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
  #35   Spotlight this post!
Unread 07-03-2010, 23:23
AKA: Simon Bohn
Re: Suspending
I think that most teams just decided that at only 1 point more than hanging, it just wasnt worth the time, and effort to make it work.
  #36   Spotlight this post!
Unread 07-03-2010, 23:37
Thuvishan.R's Avatar
Thuvishan.R Thuvishan.R is offline
FRC #1241 (THEORY6)
Thuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant future
Re: Suspending
Team 1241 hung on multiple ocations at flr, as well had the option for the suspension of another robot but due to time constraints and game play strategy never saw any possibilities to try in actuall game play.
Thuvishan Rajagulasingam
Team 1241 THEORY6 Robotics- Alumnus
Rick Hansen Secondary School
2013 FIRST World Champions (1241, 1477, 610)
  #37   Spotlight this post!
Unread 07-03-2010, 23:38
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
Re: Suspending
The last determining factor that attributed to our inability to allow another robot to suspend from our mechanism, is that the alliance selection assignments did not provide our Team with an alliance partner whose robot had the ability to suspend itself off of the tower. Since our robot is designed such that any robot with the ability to elevate from the tower also has the ability to be supported by our robot, no one was able to attempt to suspend themselves from us.
-Clinton-
Clinton, we owe you and your entire team huge thank you's. Over the last few weeks you have been a gracious host. I hope you at least got a cookie or brownie!!
I think if we had just a few more seconds and if your 2nd hook attached, it would have been incredible. I know you guys are going to go to Ann Arbor and be successful. It wouldn't surprise me at all if you didn't have 2 robots hanging off you!! Best of luck!
  #38   Spotlight this post!
Unread 08-03-2010, 22:47
RoseJ's Avatar
RoseJ RoseJ is offline
Team Captain
Team Role: Driver
RoseJ is on a distinguished road
Re: Suspending
And I would like to thank the EngiNERDS for all that they have done~ If we had a few more seconds left in the match we would have been suspended from your robot. I truly hope that our two teams continue to work together in the future when we get the chances. I'm not sure about you, but to me it seemed like the crowd went nuts when we were starting to hang off of your robot!
Genesse Robotics Area Youth Team Leviathons
Avatar/picture of Dean signing my shirt at the 2011 Ann Arbor competition.
Picture belongs to http://www.flickr.com/photos/daniele...7626367546636/
  #39   Spotlight this post!
Unread 08-03-2010, 23:52
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Re: Suspending
Here are some pictures from Daniel Ernst @ Kettering District:
Starting to hook on:
Hooked and ready to Lift:
Almost there:
2 Points:
The one hook Hang:
Be sure to check out the rest of the Kettering picture from Daniel Ernst Flickr.
1322 - Thank you for the Brownies and Cookies, you are more then welcome to come to our facility any time.
-Clinton-
