Go to Post CAD or it didn't happen - R3P0 [more]
Unread 08-03-2010, 09:34
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
FP ok to stall?
I know in years past, FP motors loved to produce magic smoke when they stall (now replaced by thermal trip). My dilemma this year is our roller (single fp) isn't geared down enough (2500rpm) and we are having trouble controlling the ball.
Question: If we run the FP motor at 30% power and stall it for no more than 10 seconds, will this still cause thermal trip/magic smoke or is this a "safe" option?
Unread 08-03-2010, 09:43
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: FP ok to stall?
The FPs have an external fan attached to their output shaft to keep them cool. Stalling the FP not only causes high current, but also stops this cooling fan. Not a good idea.
I would not suggest running an FP in stall for very long at all (not even 10 seconds).
Just my opinion.
___________________
- Tennyson, Ulysses
Unread 08-03-2010, 09:52
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: FP ok to stall?
I'm going to have to say this is a bad idea. FP motors are super sensitive to stalls, and will go up in smoke in seconds.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 08-03-2010, 09:59
ADZDEBLICK's Avatar
Re: FP ok to stall?
The only thing that makes me consider this is that when I have seen FP motors go to smoke, they have been at 100% power and stalled for at least 2 seconds. By running them at 30%, the motor would be drawing significantly less power.
I'm just wondering if anyone has tried running the FP at less than full power and still fried it?
(If not, I can resort to destructive testing but I rather ask here first)
Unread 08-03-2010, 15:34
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
Re: FP ok to stall?
The only way to effectively use fisher price motors and not product magical white smoke is to have enough gear reduction built into the system so it doesn' stall. If you manage to do that, then the motors will produce magic in the form of winning matches otherwise, there is no real solution to the problem your team is having. The window motors or cimz would be better suited for the solution you previously mentioned
FRC http://www.frc1266.com/
Battlebots http://www.mutantrobots.com/
Unread 08-03-2010, 15:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: FP ok to stall?
The FP have a thermally activated switch that protects them from getting too hot but it also prevents you from pushing them to the limits of their capability.
I thought it was fine to have intermittent use at 1/2 stall torque, but I have heard war stories that make me believe otherwise. I am planning on having a modification that will allow me to drop my motor current to 1/4 to 1/3 of the stall value during lift.
As I said, I think I should be okay for 4 seconds at 1/2 stall but I don't dare bet the farm on it...
So... ...we make contingency plans and hope we don't need them...
Joe J.
Team #88, TJ2
Unread 08-03-2010, 16:42
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Re: FP ok to stall?
Our FP is geared down 108:1, powering a 2" roller. It was stalled for about 10 seconds, there was no smoke, but a strong burning smell came out. Thankfully neither the motor nor the wires were hot, but we have a spare one ready to go just in case.
Our roller and back plate are design such that the ball doesn't get jammed in too far. The material is chosen such that it brushes a ball like getting a car wash at a gas station. The height have been modified a hundred times before it was finalized in one of the later matches at SD. All of this and we are still fine tuning it as time goes on.
Be very gentle to your FP motors... Be very gentle.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 08-03-2010, 16:54
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Re: FP ok to stall?
Fisher price are not a nice motor to use effectively. They are just too fast. The pinion (and gear) is a real pain if you need to change it for whatever reason and they hate being stalled. Personally, I'm not a fan. Can I have my big cim back please?
Unread 08-03-2010, 17:33
Re: FP ok to stall?
What Daniel meant above is the fan is internal. Frequently teams have loaded the motor significantly which slows the shaft speed to the point at which the fan is inefficient. (or they block the open slots at both ends of the motor) Regardless, stalling the motor is bad even at low throttle values. The thermal device gives no warning, the motor just stops.
Unread 08-03-2010, 17:36
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: FP ok to stall?
In 2007 the BeachBots used stalled FP's to hold our ramps closed. We did this by using substantially less than full power and gearboxes to lower the shaft speed. We had a 4:1 reduction after a BaneBots planetary gearbox, I forget if it was 16:1, 32:1 or 64:1. I think we used something like 25% power for retention, more if we actually wanted things to move.
Before we settled on this solution we did a fair amount of testing to verify that doing so would not cause problems. The motors did get slightly warm to the touch during a match, but they were not close to hot. IIRC we used the same set of motors all season.
In this situation all we had to do was prevent movement from starting, in the stowed position the ramps wanted to stay put unless there was some outside event, like a hard hit from the side.
So you can successfully stall an FP without burning it up, but you need to be pretty careful how you do it.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 08-03-2010, 18:57
pfreivald's Avatar
AKA: Patrick Freivald
Re: FP ok to stall?
We've had great luck using a FP by cutting down the gearbox to whatever state best fits our application. Two years in a row, we have rollers powered by FPs with the third stage on the plastic gearbox removed, and they have been tremendously reliable.
That said, I don't know that *any* motor likes to stall for very long when hooked to a 12V battery...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 08-03-2010, 19:30
Colin's Avatar
Colin Colin is offline
FRC #0254
Colin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond repute
Re: FP ok to stall?
ChrisH,
I'm probably wrong, but I thought you guys used the BaneBot motors on your ramps and the fps on your arm in 2007.
Another option if your still worried about stalling though, is to put some kind of slip clutch into your system so that if the ball jams the fp motor will not stall.
Unread 08-03-2010, 21:42
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: FP ok to stall?
I love the FP motors. At least I did before the Thermal protection was added. I think I will end up liking it just as much with the breaker, if not more. They are easily the most power dense motors in the kit. Used with a Dewalt transmission or a Banebot transmission designed to be loaded properly (<1/3 stall torque if planned to be stalled for any duration of time) the motor is a real work horse.
Just one man's opinion.
Joe J.
Team #88, TJ2
Unread 09-03-2010, 00:11
MJ Miller's Avatar
MJ Miller MJ Miller is offline
Control System Mentor
FRC #4910 (Robohounds)
MJ Miller is an unknown quantity at this point
Re: FP ok to stall?
We're using 2 FP (one at each end of the roller) running at 30% power. In another thread I read running FP's above about 50% under load will lead to the motor failing. I didn't verify the claim. But our trick has been to drive the roller with rubber o-rings. At first, we used special pulleys machined to press onto the FP shaft. The motors didn't stall, but the roller would resulting in burned and broken o-rings. Then, by accident we noticed during additional testing that one o-ring had slipped off the pulley and was running just on the motor shaft. We noticed that seemed to work by allowing the o-ring to slip on the shaft when the roller stalled. We made it through the entire Bayou regional last week, including elimination rounds, without losing an o-ring! Give it a try.
MJ
Mentor, Team 1421
Unread 09-03-2010, 00:23
MJ Miller's Avatar
Re: FP ok to stall?
MJ
Mentor, Team 1421
Toughbox stall torque Galum Motors 4 04-02-2010 15:47
motor stall current vs Victor ratings dawilliams Electrical 30 03-01-2007 08:29
Made to stall srjjs Motors 5 17-01-2003 19:00
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
